car energy consume improvements
Started by lancaIV, July 02, 2016, 07:40:03 AM
kolbacict
Tell me please,where come this personage from ? film?
I saw that film very long time. I want to watch it again. But don't know it name.
There were evil mother and children. And a sailboat in the grotto at the end. :)
Kyoto- conference : 1990-2050  - 80% Greenhousegas-Emission reduction
Paris-conference : reduction from Global-Warmpotential to maximal +1,5°C from average
An internal combustion engine its gas process temperature output from the tail pipe : 350°C
Each liter liquid becomes by explosion a gas,mixed with extra introduced atmospheric air a huge heated gas volume per driven kilometer !
https://www.google.com/url?q=http://www.adilca.com/FUEL_COMBUSTION.pdf&sa=U&ved=2ahUKEwiU7c2Uy6mBAxXFT6QEHSduDWcQFnoECAEQAg&usg=AOvVaw3qt7QB2uB-kRAPxGwHeS_M
The combustion of 1 kilogram of diesel fuel requires about 14.6 kilograms of air
(that is, given the composition of the air, about 11.2 kilograms of nitrogen and 3.4
kilograms of oxygen); the reaction produces about 11.2 kilograms of nitrogen (this gas
being chemically neutral, it did not participate in the combustion), 3.2 kilograms of carbon
dioxide (CO2) and 1.2 kilograms of water (H2O).
- The combustion of 1 kilogram of gasoline requires about 15.3 kilograms of air (that
is, given the composition of the air, about 11.8 kilograms of nitrogen and 3.5 kilograms of
oxygen); the reaction produces about 11.8 kilograms of nitrogen (this gas being chemically
neutral, it did not participate in the combustion), 3.1 kilograms of carbon dioxide (CO2) and
1.4 kilograms of water (H2O).
350°C /ambiental seasonal temperature : air dehumidification : condensation enthalpy = temperature increase
Heat-island effect !
Independent from (liquid,gas) combustion fuel kind,a-/biotic,bio-/syn-/e-fuel,hydrogen,NH3 et cetera !
A geral 'ic'-/heat engine~ ambiental heater/dryer dilemma !
By using electricity to be critical about natural resources ab-/use :
https://spectrum.ieee.org/how-much-water-does-it-take-to-make-electricity
"That translates to an average of 95 L of water to produce 1 kilowatt-hour of electricity,"
The researchers also looked at water consumption by type of electricity generation:
https://spectrum.ieee.org/media-library/image.jpg?id=26412884&width=284&quality=80
'personal destruction fingerprint' !
wmbr
OCWL
onepower
mbm
QuoteHey onepower, just a short history lesson for you  ;)
Fletcher Prouty Explains Invention and Use of Term "Fossil Fuels"
https://www.youtube.com/watch?v=zSff0pwc1Xc
Interesting video and typical of most misinformation and propaganda.
I think it's comical because I have no problem showing the guy is a complete moron.
1)The notion that because oil was found below 33,000 feet it cannot come from plant/animal material is absurd. The Earth's crust is always changing and like water oil/gas moves through permeable ground until it hits the rock sides of a formation. Cracked and/or broken formations could allow oil to go much deeper than 33,000 feet. In fact, fracking fractures/cracks the formations increasing oil production doing as much. I used to work on a drilling rig and field operations(compressor station, 450 wells). So it's easy to spot stupid people claiming stupid things like in the video.
2)I also built and tested many Pyrolysis units which use heat and pressure to convert any organic material into oil just like the Earth does. So when some moron like in the video implies oil cannot come from organic material it's absurd. I literally built my own Pyrolysis units that do exactly what he claimed cannot happen.
3)Here's a clue, fracking chemicals are showing up in very deep water formations and can travels hundreds of miles horizontally. They frack a hole and 50 miles away the water goes to shit and gas starts coming out a person's water faucet. Even a child could put two and two together and figure out water, gas, oil and chemicals are always moving around from one formation to another.
So the only history lesson you have shown is that there's always morons trying to dupe people into believing nonsensical things to serve there interests. Every conman, shill and troll has come crawling out from under there rock with the rise of populism. However I'm sure free and clean energy will prevail. Progress waits for no man.
AC
SolarLab
Wondering if these "Boost Converters" have any "Gain"  :)
"This paper presents a reactor core for boost converters used in automotive motor drive systems for
HEVs and PHEVs, etc. (Fig. 1). A reactor is designed to (i) convert (boost) the voltage by alternately
accumulating and releasing the magnetic energy and (ii)  smoothing the ripple current that is
generated in the boosting process. The core is the key component to achieve the reactor's functions."
Attached pdf:  "Pure Iron Based Soft Magnetic Composite Core That Enables Downsizing Automotive Reactors"
SL
SolarLab
"To this end, each system mainly employs a power unit
with a boost circuit (Fig. 1) that increases the battery
voltage of 200-300 V to the motor-driving voltage of
400-800 V 1)-3) "
"The reactor in a booster circuit is a core
component that serves to boost the input voltage
from the inverter with the action of, switching
devices that turn on and off to alternately charge and
discharge magnetic energy, and to smooth the ripple
in the electric current generated during the voltage
conversion."
Attached PDF:
"Low Loss Reaactor Comprising Dust Core {SMC} and Copperbelt Core"
SL
