use pulleys to multiply total # of rotations = AC electricity
Started by that_prophet, July 02, 2016, 11:35:19 AM
Paul-R
Citfa is completely correct.
Anyway, if you put a spark of DC of appropriate voltage into most DC motors they would probably fail.
You need to begin by understanding :
leverage
power and energy
voltage and amperage
that_prophet
Quote from: citfta on October 14, 2016, 07:05:13 AM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
that_prophet
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
REPLY BY ME
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
citfta
that_prophet
 Free energy is as simple as the pre-school technology of using pulleys to multiply rotations
+ multiplying AC electricity with multiples of both size and #'s of pulleys
= https://free-energy.yolasite.com/
- this is so super simple,
that we should be ashamed of allowing satan
+ his fellow evil spirits, to have kept it hidden
for so long = ever since Ezekiel 1:16
- "a wheel in the middle of a wheel",
where it was the first simplistic described how a UFO motor worked in the Holy Bible,.
You only pay one small bit of DC current
to rotate 100 cm circumference pulley one single time,,,,
+ through running the 100 cm of moving belt,
(which came off the circumference of pulley)
+ running it by 10 of the mini- 1cm circumference pulleys
+ attaching AC generators to each pulley,
you can multiply your AC electricity to 10X100=1000 cycles of AC electricity
,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one spark of DC current
=(just enough to rotate your DC motor one single time)  .  .  .   .  .  .  .  .  .  .  .  .  .  .  .  .  .  .   .  .  .  .
<<< NOW TRY + TELL ME THAT YOU CANNOT GET ENOUGH VOLTAGE FROM THESE 1000 CYCLES OF AC ELECTRICITY,,, + ONLY THE ONE SPARK OF CURRENT, THAT IT TAKES TO ROTATE YOUR DC MOTOR ONE SINGLE TIME >>>
(I hope this makes you realize reality, + how powerful spiritual warfare is going on all around you every day)
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04=Door –(in air for all born-again who are looking for His Coming)
although we are warned that "of that day and hour knoweth no man"-Mat 24:36,
we are also told that we can "know that it is near, even at the doors"-Mat 24:33
Just think of it this way, you are only putting in one small bit of DC current,
Enough to crank over your DC motor once, with a 100 cm circumference pulley attached,
+ through simple pre-school  pulley mechanics, of running this 100 cm of moving belt,
that comes off the one rotation of your 100 cm circumference pulley,
Past 10 mini-pulleys of 1 cm circumference, with free running AC motors/generators attached,
+ you will get 10 X 100 = 1000 cycles of AC electricity.
All for the cost of DC current to rotate your DC motor one single time = only one spark
http://decimationofthisevolutionfairytale.yolasite.com/
http://free-energy.yolasite.com/
http://my2020vision.yolasite.com/
http://doorschristmustpassthrough.yolasite.com/
http://beliefstoliveby.yolasite.com/
http://fire-starter.yolasite.com/
http://2020vision.yolasite.com/
http://one-christian-warrior.yolasite.com/
