Rotating magnetic fields
Started by Grumpy, November 09, 2006, 11:53:46 AM
Grumpy
rotating electric field will gain energy - mag field contains it.
not required for radiant energy.   See Turbo's version?
        -Frank Edwards
lightbody
ahura mazda....jan 5th ..."seen this...or this.. between them these two links hold the key"
  See what or what- URL's missing.
What? I want to see.
AhuraMazda
LB,
See the files that were attached in my previous posts in this topic.
AM
Lance
Regards rotating field in Otto's TPU collector assembly:
I suspect Otto's 'control' coil assembly is producing a rotating field around the collector...
Treating the control windings as two pairs of motor stator windings placed at 90 degrees we would normally drive each pair with a separate AC source with at least one source being phase shifted by 90 degrees (in current) to generate a rotating magnetic field.
NOTE: To use one source and derive the second we would use a motor capacitor in series with the second winding pair to generate a phase shift.
We can also use an inductor to phase shift the signal! - Isn't this just what Otto is doing by connecting the two winding pairs in series. The first winding will add a phase shift for the second!
giantkiller
Quote from: AhuraMazda on January 05, 2007, 06:37:14 PM
Grumpy,
I know you have been contributing for a long time. What does your instinct tell you? Personally I believe a rotating field to be essential. I hope GK pull's out an ACE but I am not holding my breath.
AM
You can breathe now...
--giantkiller.
