Better version of Don Smith generator
Started by FreeEnergyE, August 08, 2016, 06:40:20 AM
FreeEnergyE
Hello,
This is my first post on this forum. ;)
I am building a Don Smith generator with guide in attachments, it is better because it does not require earth connection, it uses Tesla biffilar coil with extended capacity instead of L1. In guide I found all equations. My question is how I can, in case output of 30kW, step down voltage from high to 230V 50Hz without transformer, and if I can to convert to the three phase, without using motor, and if I can't step down voltage, can I make L2 coil produce 230V directly and how I can later convert high frequency to 50Hz?
And can I use other material in constructing Extended Tesla Biffilar Coil?
Please read that in guide and tell me.
Thanks!
magnetman12003
Quote from: FreeEnergyE on August 08, 2016, 06:40:20 AM
Hello,
Thanks!    Whatever coil you make that generates hi frequency and hi voltage can be rectified  easily to DC.  A inexpensive solid state diode full wave bridge rectifier can do the job with an output capacitor,  Then work with the DC voltage,
saintsnick
 "In guide I found all equations."
Ummm, what guide? Please elaborate.
Thanks...
-sNick
FatBird
The guide you will get for FREE when you download it
AFTER you click on his Link.
(is it really that complicated?)
