Perpetual Energy Wheel
Started by vikram_gupta11, August 15, 2016, 06:16:01 AM
vikram_gupta11
This Idea is based on Magnetic Repulsion and Kinetic force.
According to diagram there will be a  Wheel and a magnet(1) will be attached with this wheel. There will be a balance system(seesaw system) and two magnets(2no.magnet and 3no. magnet) will be attached with this balance system .
when 1 magnet will repel 2 no.magnet then the 2 no.magnet will move upward and due to this movement the 3 no. magnet will come down and will work to repel 1 no. magnet and wheel will start to rotate.
when 1 no. magnet will again repel 2 no.magnet after a rotation then the 3 no. magnet will again work to repel the 1 no.magnet.
THE weight of magnets of balance system will be equal.
In this way the wheel will rotate again and again.The magnetic strength of 1 no. magnet will be high than 2 no. and magnetic strength of 3 no. magnet will be high than 1 no. magnet.
Smann
Honestly, I do not believe such things are possible...it will stop eventually.
vikram_gupta11
It will not stop as this machine is fulfilling all the requirements to be a perpetual machine and this machine is getting initial energy with itself power to rotate so it will work.
Low-Q
Easier to see the whole picture...
citfta
If number 1 magnet is repelling number 2 magnet that means that number 2 magnet is also repelling number 1 magnet so what will happen is as number 1 gets close to number 2 then it will stop and not actually move number 2 magnet.  You can't have  the magnets only acting in one direction.  Whatever force number 1 applies to number 2 is also applied back to number 1 and therefore it will stop the wheel from turning.  Sorry, but you really need to spend some time actually working with magnets and then you would see this.
Respectfully,
Carroll
