Increase the potential energy without any energy
Started by activ25, September 24, 2016, 11:14:10 PM
Low-Q
LancaIV
                          usually reply
                        http://www.nonsense.com
strange
                                  , and place
             1/2^7
       the                 %               €      words all
over the place.
                            VIDAr
Quote from: activ25 on September 21, 2017, 02:32:02 PM
It was the old device... I found my error a long time ago. The new device is in the pdf file, it is not the triangle. The pdf file has 4 pages.
                    the reply5-pdf ?
                                               not impossible,but
blue spheres will becoming dots and the shaft a light Spot : no classical mechanical,
        but quantum mechanical
f.e. spanisch patent,approved and granted
                                            1€Cent/KWh champion-ship
activ25
#5 file "text-inv-3.pdf"
At final, the device is a square
LowQ: so lancalV is a troll, why ADMIN don't destroy its account?
activ25,read all this thread replies,think about faults,educational and technical,then you are invited to become respected.
It is your -own tutorial- must to delete or minimal give advice about arithmetical errors in your own calculations,not our.
                 the not above doing- this is real troll-ing
Actually you are a "nobody",virtual and real.
wr
    OCWL
p.s.: I normally invest my time in usefull and functional thinks
                                 and things
        and administrated a project which became technical
        approved and granted.
              TECHNICAL STANDART= "Peers degree solution"
               this will be -in memoriam Otto Stein-
                     "DIE ZUKUNFT DER TECHNIK"
                         Lord Kelvin meets Kirchhoff
                  https://books.google.pt/books?id=vSIUAwAAQBAJ&pg=PA488&lpg=PA488&dq=lord+kelvin+spring+condensator&source=bl&ots=FXetmoTC2X&sig=7OTyXNq2Mf8pStwIMGPlsAfw4Jw&hl=de&sa=X&ved=0ahUKEwiZqpXtr7jWAhXF0xoKHYOdB4MQ6AEIXjAM#v=onepage&q=lord%20kelvin%20spring%20condensator&f=false
