The Musings of Smudge [Cyril Smith
Started by ramset, October 01, 2016, 05:40:52 AM
barbosi
Allcanadian,
After too many years I found your idea about THE bearing and I have very little to say beside BRILLIANT.
I apologize for this off topic digression but your recorded presence online is rather scarce. As you put it,
Quote from: allcanadian on October 02, 2016, 05:26:06 PM
one moment it's there and in another it's not.
So I had to take publicly the opportunity...
Bravo.
When the Power of Love overcomes the Love of Power, there will be peace.
allcanadian
@Barbosi
QuoteAfter too many years I found your idea about THE bearing and I have very little to say beside BRILLIANT.
Thank you barbosi, I hope you and others find it useful. The last prototype is now collecting dust under my bench and the last run was with a 20 lb rotor spun up to around 3000 RPM. It freewheeled for days and I finally got bored watching it so I stuck it under the bench.
It was disclosed with no string attached open source for all to use.
AC
ramset
AllCanadian
gratitude here also for your Mag Bearing work/share
More progress from Over unity research  forum
http://www.overunityresearch.com/index.php?topic=3345.msg57522;topicseen#msg57522
One Link would not load here and the forum dumped the whole post I had made with all the circuits and other info,
I will redo this later.
**adding Docs as time permits
all comments and contributions welcome.
respectfully
Chet K
Thanks Grandma
allcanadian
@Barbosi
To expand on my post.
The true value of any given device such as my magnetic bearing is in understanding the "concept". I create two very large forces which cancel one another perfectly and most everyone concluded the sum of forces must always be zero therefore it has no value. However that is not what my concept implies, far from it, it implies two forces may cancel one another perfectly and in doing so create a third force which becomes an independent force. The third force cannot translate back to the forces which created it thus the load has become truly independent in itself.
This is a universal concept, we see two charges with opposite polarities come together and negate each other at which point their external field ceases to exist. We see a magnet with two opposite polarities and when they come together and negate each other the external field ceases to exist. My concept implies perhaps we should use three, a trinity of unions, two negating their own existence to produce a third resultant force independent from all others.
Three pairs, six unions, nine forces changing in time...
You see the value is not in the fact I invented a 99.99% passive magnetic bearing now collecting dust under my bench but in understanding the universal concepts I used to create it. My bearing is just an object and the fact it is collecting dust indicates it's value to me but the concepts I learned... I carry with me in everything I do.
Philosophy, curiosity, concepts, understanding then application is the way forward my friends.
AC
ramset
The investigation moves forward
here
http://www.overunityresearch.com/index.php?topic=3345.50
Additional Docs  below .
respectfully
Chet K
Thanks Grandma
