Thanks to ALL for your help!!
neon sign transformer confusion
Started by Tesluh, October 25, 2016, 12:08:02 AM
Tesluh
Good find!  if the ones I ordered don't work I will get those from Germany.
memoryman
"Going to order 4 of these and try 2x2 series and parallel for .2uf@6000vdc" that will give you 0.1uF @ 6kV.
Magluvin
Quote from: memoryman on October 26, 2016, 07:33:45 PM
Yeah.  If he uses 2 from that link in parallel it should be good with 2kv headroom.  That is if the caps are only .1uf each in the pic as he says. Just by the looks of them, I kinda lean toward them being 1uf 4kv. They are not small physically either.
The next thing to guess would be the voltage breakdown of the spark gap/suppressor. Diodes can probably be dictated by the cap voltage limits. If the red leads go out to the primary coil, Im not seeing how the primary gets powered by this circuit unless the nst is just a driver for the L and C. That must be it. so the nst freq can determine the LC resonant freq design.  Weird circuit.   I dont think it can be that the nst slowly pumps up the cap till spark, as the primary is across the cap and should be preventing that, I think.  Again, its weird
Mags
Mags
Magluvin
Quote from: Magluvin on October 26, 2016, 11:25:43 PM
Mags
Mags
I misread. 2 in parallel is still only 3kv. would need 8 to be .2uf at 6kv
Mags
Tesluh
cmr1a 402104k custom electric is what Don used (x2 in parallel) on one of the boards I saw a close up of.  .1uf at 4000wvdc, i think its a mica construction.  Not saying that only that one will work.  and dang it I will need 8 to get .2uf at 6000v!  4 in series paralleled with 4 more in series, 2x4.  thank you for pointing that out!
