LCAP (Again) Possible Free Energy. (Voltage Gain Over time)
Started by TheGeneralHackr, October 28, 2016, 11:57:07 PM
TheGeneralHackr
Quote from: itsu on October 30, 2016, 06:20:43 AM
TGH,
after your last FWBR modification i got it to work (kind of).
I had to reverse the led and i had to also connect the emitter to minus (-)
My AC leads are reversed versus your diagram.
I am using 2x AA rechargeables, at 2.4V for the moment.
The collector signal is shown in the screenhot below.
Using a 470nF poly cap, so no tantalum.
Voltage slowly dropping on the batteries........
Regards Itsu
Yes, it should be grounded before the bridge and at the emitter of the transistor.
There should be 1-3Mohm resistance on the base, even if its not a led.
Your frequency is too high, I had around that same frequency in the scope shots but that was only when the circuit was running "wide open" The frequency should be around 5hz-10hz when the potentiometer is cranked up to 1 Mohm, you should hear a audible clicking sound. It should be around 5-10hz
If moving the pot up to 1 Mohm doesn't help try removing the 470nf and the potentiometer temporarily and replacing them with a single 470uf 16 volt electrolytic capacitor. (You should hear the clicking sound I'm talking about for around 10 seconds before it fades off)
Here are the images on how I connected the emitter to the ground and bridge rectifier.
itsu
TGH,
your images are way to big, please shrink them down first using paint or so,  thanks.
oK, new screenshot shows a 12Hz signal which can be lowered (or raised) somewhat using the 1M potmeter.
The white led is visible blinking now (12Hz)
Batteries voltage is stable at 2.513V, slightly climbing, probably due to earlier heavier load.
The LED needs to be opposite as to what your diagram shows, else it won't work.
I will continue to monitor the batteries voltage......
Regards Itsu
itsu
Batteries voltage at 2.525V and still climbing slowly.........
Itsu
TheGeneralHackr
Quote from: itsu on October 30, 2016, 03:33:33 PM
Itsu
Excellent I'm glad you got it to work. 12hz sounds about spot on.
If you raise the input voltage the voltage will climb faster in the long run
itsu
I left the circuit running overnight with a voltage of 2.528V, and this morning it was at 2.534V and seems to be stable now.
I will keep it undisturbed for the rest of the day.
I have a supercapacitorbank (100F at 15V) which i will "fill" to 5V and let it run from that for a while as a next step.
Regards Itsu
