Why Over-Unity is Possible
Started by pauldude000, November 16, 2016, 09:39:04 PM
Turbo
Quote from: forest on November 24, 2016, 02:11:17 AM
Think twice how is the current generated by induction and you will be struck by this simple fact.
You should ask yourself this question and it's not a simple fact.
You want to talk about facts, Mister Forrest?
Here's a fact which i will give you for free.
that_prophet
over-unity is easily done with pulleys, mechanically multiplying rotations + since AC electricity is made by using rotations,
you are actually multiplying you AC electricity,,,, it is truly that simple
.       This is so dirt simple that you will kick yourself, after you discover just how super simple this technology truly is. How is AC electricity made, by using rotations of a coil through a magnetic field, and we can use a set of varying sized pulleys to multiply your total # of rotations. So, we can effectively multiply our amount of AC electricity by using simple pulley mechanics.
.      This GEM = (Geometrical Electricity Multiplication) technology is super simple, http://free-energy.yolasite.com/ and is based on basic pulley mechanics. In it, you pay a small amount of DC electricity to rotate a large 100 cm circumference pulley one single time, (one mere spark). Then you run the 100 cm of moving belt, (off the 100 cm of circumference) past a mini-pulley of only one centimeter circumference, giving you 100 rotations, which you covert into 100 cycles of AC electricity, by simply adding an AC generator to it. You are merely using the 100 cm of belt that you get off the single rotation of a 100 cm circumference + by running this length of belt by a 1 cm circumference pulley, with an AC generator attached.
.     Now, you have just multiplied your single burst of DC current into 100 cycles of AC electricity. Please don't listen to the mythical torque problem, because there is no torque problem. This AC generator is running practically torque free, because all that it has to generate is the single burst of DC current that your DC drive motor takes to make one rotation. And please remember, that you get 100 cycles of AC electricity to generate this single "spark" of DC current to power your drive motor, so this is generating practically zero current, divided by 100.
.     If you run wires from your AC generator output, + put them into the input of a full wave bridge rectifier,(4 diodes) + then run wires from the DC output of your full wave bridge rectifier, into the input of your DC drive motor, you should have a working mechanism. This perpetual free energy generator mechanism is complete, + you should be able to start it running by merely rotating the large pulley by hand, a quarter turn.
.     Please don't listen to the torque problem, as it is non-existent. This AC generator is pretty much free floating, as for all of its 100 rotations, it only has to generate one small spark of DC current. That is one small spark of current, that is divided by 100, so you only have to generate 1/100th of a spark of current per rotation, or 1/100th of practically nothing.
.     You must have your AC generator + your DC drive motor of the same voltage.
.     This is so simple + cheap to build guys + gals, please build one to prove it works,,,
I live in a nursing home, so I cannot even have the simple tools to build this with. This is so dirt simple + easy to build, that satan is laughing his as? Off, at how gullible we simple humans are. But he will get his just deserts, when Jesus returns in His Glory, before the second door close on 2025.94 = 2019.04(door for rapture) + 6.9(7 Hebrew years = 2520 days) http://doorschristmustpassthrough.yolasite.com/
.     So we have less than 19 months to live, before all born again followers of Christ, only those who are looking for His Return, will vanish off this earth in the Rapture = "blessed hope" http://my2020vision.yolasite.com/ http://beliefstoliveby.yolasite.com/
forest
Mister Turboo
If you find a single case of electric induction generator working without magnetic field you can apply for the Nobel Prize
meanwhile do not spam this thread with useless pictures
endlessoceans
Quote from: forest on November 23, 2016, 01:12:57 AM
It is very very simple. take a coil, power with dc, measure field.Take a ferromagnetic core insert into and measure field. You have found OU.
WRONG!!  Again
See its with daft statements like these that you Tito/Forest/Whatever show how uninformed you are.
The above having been said, the error in your experiment was the ACCURATE measurement of the wattage used in each repulsion test of different magnets of different strengths.  Measure total wattage from your battery.  Yes, the voltage may have been 9VDC in each case, but the current was much higher due to the higher inductive force with iron core.
If youre going to troll around here and drop extraordinary statements then this requires extraordinary proof.  Make a little coil with a supercap and diode and then put your iron core or magnet in whatever arrangement you like, pot it in resin so we cant see it, then show a lit LED and the climbing measurement of the voltage in the supercap.  EASY you say....abundant energy you claim.  Solder it up in 10 mins no problem.
Either that or shutup
forest
what is "inductive force with iron core" ? coil has no inductive reactance for DC or pulse DC
the same coil with or without iron core has different strength of magnetic field and that's the main reason for different induced EMF
