TD replications
Started by Floor, November 18, 2016, 11:14:23 AM
0 Members and 28 Guests are viewing this topic.
forest
After 20 years of watching various free energy devices my conclusion is simple: magnetic field is source of energy.Im curious what do you think
ayeaye
Quote from: forest on February 26, 2020, 12:43:08 PM
Yes i think the same, but i think the reason is asymmetry of the magnetic field, that is non-Coulomb irregularity. Come both from the Maxwell equations, and experiments seem to show that.
ayeaye
So all i understand, the magnet is initially twisted. When releasing it, it untwists. But why should it then twist when bringing magnets back together again?
Or i need a clear drawing where the orientation of magnets is clearly seen at every stage. And no skewed magnets on the drawing.
norman6538
Here are 2 photos of  my second attempt that show the device. 1st is the magnet gap open and on the right you see 2 stacked RadioShack rectangular magnets with the hole in the middle  mounted on a tongue depressor to allow it to pivot up close to the other twisting magnet on the left.
2nd is with the magnet gap closed showing the left magnet twisted up and lifting 2 3/16 washers up 2 cm. It takes very little work to close and open the gap. This was my 2nd attempt. Today I quickly remeasured 5.5 cm lift of 12 BBs = 66 units and closing the gap required 6.5 cm x 3 BBs = 19.5 giving 338%.
The green twisty in the photo was used to attach 2 washers to the crank  which shows you how I work quick and dirty till the concept is valid. I have switched to BBs because they are  more precise. By adding or subtracting a BB at a time you can determine the max power. I made  bucket to hole the BBs from a  plastic coffee creamer.
Sorry the photo does not match this latest measurement technique of using BBs.
That tongue depressor wood on the right is a stop to limit the rotation - again quick and dirty broken off and hot glued in place.
True OU. And a 2 sec video to shows the lifting as the gap closes.
Today I drew up the method to feed the lifted output back to the input to make it self run.
And remember my latest version 7 has a ratio of 1:40 units out - 4,000% efficient   because I changed some geometry and leverages after hours of experiments. The last versions us a hinged door to move the magnet up closer to magnetically twist  the rotating magnet. This all came together in just over a weeks time.
Again Floor,  I say thank you for sharing all of your experimenting that has led to this replication and measurements.
I added the principle drawing below.
To get yourself started take a McDonald's coffee cup and put some weight in the bottom to hold it in place. Poke 2 holes straight through with a large paperclip carefully straightened out with a vice and pliers. The bend one end at 90 degrees and seriously hotglue the axle and magnet so you can then manually move a magnet up to and away  from  it and see the twisting but you will want to limit that twisting or it will just  get stuck together.
Norman
norman6538
Here is how you can jumpstart in 15 mins. Take a small coffee cup and poke 2 holes evenly in both sides with a large paper clip straightened out on a vise or with pliers. Hold the end with a pliers tight and poke the hole through. Then bend a 90 degree angle at one end and seriously hot glue that to the center of a RadioShack rectangle magnet with a hole in the center. Cut 2 1/2 in. squares from the plastic  of a milk jug and push those on the wire to act like hubcaps to hold the wire in place so it does not move end to end. You can see I put wheel weights in the cup to hold it in place.
Then play with it. I also hot glued the other magnet to a wood block at the same height as the twistable magnet. And I added a small wood dowel to limit the rotation.
And play play play.
Norman
