Earth Energy Batteries
Started by FreeEnergy, April 20, 2005, 08:31:00 PM
cletushowell
I will try plug a iphone charger or any dc charger
in your combining ac and dc on neutral
side oscilating it with the black power side
between the neutral and ground is 37 volts ac or so
on a 5 v dc charger your not using power
step the dc up to a say computer charger you get stuck
at 60 v ac the oscilation of the hz
take that to a car coil it transmits wireless inside the coil
some how reverse the points its overlimit ac
unlimted energy
so 60 volts unlimted wireslessy on the
neutral
now go 120 to three car coils
bridge the post take six wires to
a motor run it now you have
120 and 60
but also dc two my coils fried
my system is down it was powering a drill
and radio its combining the hz in the coil
essentialy filling the gaps in the hz
its pretty complicated to explain heres the videos
i made my own ground using my square wave
  Check out this video on YouTube:
http://www.youtube.com/watch?v=RYJaYEIEgaw&feature=youtube_gdata_player
http://www.youtube.com/watch?v=AjADPX-q1tg&feature=youtube_gdata_player
email me direct if you have questions
they get mad when i post here
ch@helpuflip.com
kooler
question here
i made a pot scruber battery like lidmotor did in the yard worked good..
then i had two scrubers left so i found a plastic coffee container and put them in it..
copper on bottom and dirt then steel one then dirt.. but i mixed some iron filings with my dirt before i put it together..
then came plain tap water.. city water.. nothing in it no salt no nothing..
voltage check = 0.45 volts  normal
amp check = 5.4 ma's  normal
so i put 2 more ounces.. water
15 mins later no voltage.. nothing.. but
the container is warm to the touch.. ??
i told my wife she felt it and said whats causing that..
is this normal ?? it is starting to get a little kooler..
first time i ever mixed iron to my dirt before..
any clues .. please
robbie
Pirate88179
Robbie:
I am not clear.  Was your can buried in the ground?
ElectricGoose
Quote from: kooler on September 25, 2010, 11:16:34 PM
question here
any clues .. please
robbie
Heya Robbie
OK, get ready to switch the mind to the 'organic' side man.   ;D
What are your feelings or beliefs on Orgone/Orgonite?  I think what you MIGHT be sensing is not true 'thermal' heat (as registered by instruments) but a organic interaction between your nervous system and the 'organite mix' within the can which is emitting FIR (and then translated by your nervous system as heat).  It explains why you are not reading any voltage.
There is a TRUE science behind it that is not well understood and very difficult to tap.
E-Goose
jeanna
....l
the container is warm to the touch.. ??....
any clues .. please
robbie
In the winter the hardware store sells handwarmers.
These things have some very simple ingredients and iron powder is one of them.
You added water.
These are sealed and when air mixes they turn hot.
When they stop working they smell a little like rust.
Maybe you have found the secret ingredient mix for hand warmers?
I realize this is not an answer.
...more like another question.
jeanna
