Reality and it's transmission of force and energy
Started by jbignes5, December 24, 2016, 10:31:45 AM
jbignes5
Quote from: Acca on December 27, 2016, 03:07:59 PM
Here it is....
I have investigated the effect of a neon gas bulb and the plasma effect is manifested in the neon gas of such bulb.
I will post some clips that I did some 7 years ago,  neon goes to bright white white purple and violet color.
The emission of plasma in bulb is there just as the Pap effect.
The use of a cold plasma tubes is very easy to make the effect especially in a very small neon bulb.
What is amazing is this effect has been known in science for a very long time ...
However it is not part of plasma physics university education..
You are very right this is a very dangerous effect to say that it alters the energy balance on earth..
So long ..
Keep on Acca....
Yeah a good researcher in the pap device is RWG research but I don't think he knows exactly what he is looking at. When I tried to help him with it he only got more confused so.. But there is something to the expansion between the particles of the gas. That expansion is actually a plasma attracted and condensed through the walls of the container. Since matter has bound plasma between it it uses those channels to suck in more plasma as the discharge happens. Stopping the discharge lets tha plasma expand and filter back out of the container through the conductors between matter. This is done by the magician trick of pulling the table cloth from underneath the china on the table effect. The faster you pull it the less effect you have on real matter resting on the cloth. The sharper the impulse the less effect it has on matter itself except where you want it to effect it. Ie solenoid coils and the self induction they cause.
Using a bifilar inside of that solenoid allows you to impulse as fast as possible to a ground. The solenoid then induces a flow within it's matter and a real current is the results, complete with the Bemf associated with the self inductance of the solenoid. Or an AC result. Maybe... I need to start testing this experimentally. Others have and have had great results but if the system doesn't have a clear in and out then it still balances out and nothing real can be gained except for the wiring of the circuit attracting the plasma and being uneven induces a flow around the circuit.
The system will have to be monitored so that it doesn't disrupt the natural pressures inside of our planet but it should be very easy to do that. Balance is the key there. But we can make local versions with virtual grounds to separate the flows from our planetary system. Only using the virtual ground as a reference to the ground state but looping the plasma flow via an in and out as I suggested. Like in the Tesla experiment of the pierce arrow where the in and out was actually between the antenna and virtual ground of the body of that luxury car. If one chooses to use the ground then it already has a vacuum effect already going. The input to that system is the spark gap and the output is naturally the ground itself, which has a vacuum of plasma.
Gravity is nothing more then an effect of that vacuum across the boundary layer of the surface of the Earth. Earth systems will be the strongest but non Earth bound systems can be used with virtual grounds and the flows setup between those elements. Sorta like a pump. Once the pressure of plasma is created you just induce off of the flow of that pressure.
Now where does all this plasma come from. Well it is from the solar wind our Sun provides with it's connection to the galactic flow of plasma from the center of the disk. Plasma is all around us due to the condensing of the plasma from between the particles of the gas flowing with the solar wind. It is filling our planets atmosphere with this conductor with neutral conductors stacking up around the planet in layers and the charged plasma flowing between the matter to ground. Once in the ground it condenses(looses charge or crimps in the plasma lines between matter further and reduces the dynamic size of the charge carriers to facilitate the distance reduction between matter the closer you get to our core.
The solar circuit is pressurizing all around us via resistance to the flow of plasma that matter makes. If we do not let some of that pressure off and take energy from the system then our future is bleak and full of destructive forces. All of the effects of Global warming is due to this pressure growing and space becoming better at transmitting energy and force due to the increased plasma between matter. This is the only way to make our planet livable again. By reducing the plasma from around our planet we can re-stabilize the system and force the system to balance due to a bidirectional flow plasma can have. After all everything is connected right?
Resonance is the ket to this mechanism. Resonance to the plasma will bypass the resistance and act like a clear channel in and around our planet. Altering this system correctly will allow us to balance the system without destroying our humanity. Leaving it the way it is will kill us in the end. We must act and we must act with knowledge of the medium of space and how it works.
Acca
 Here is what I did many years ago ...and the effects of plasma ..
These are not for public view just with these links the clips can be seen ..
https://youtu.be/d5WFY4aynUs
https://www.youtube.com/watch?v=q3da2GpcTrQ
Btw I have moved to bigger plasma effects and you are right on, discovery of the cold
plasma has is very real effects on matter and the way it reacts with local space time ..
I will not bring up this topic again as it is not for public debate..
Thanks for that new thread ... brings back old forgotten effects ..
Keep on...
Acca... [/font]
jbignes5
Quote from: Acca on December 27, 2016, 10:00:10 PM
Keep on...
Acca... [/font]
Thanks for that.. I appreciate the additional content. Very nice work by the way.
Isn't it funny how each plasmoid is different like a snowflake. No two are the same.
Dog-One
Quote from: TinselKoala on December 28, 2016, 12:17:43 AM
http://www.youtube.com/watch?v=pLCOBzuxIWQ
You've done some really far out stuff over the years Tinsel.
I sure wish one night would come when you see it, clear as day,
what needs to be done to put it all together and crack this egg
of stone we have all been hammering on for so long.
