GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
This is so simple that it just has to work.
It only takes one spark of DC current to rotate a DC motor one single time,
+ If you attach a 100 cm circumference pulley to this DC motor it will give you 100 cm
of moving belt Then, if you run this 100 cm of belt past 10 of these free running 1 cm circumference mini pulleys you would get 10 X 100 = 1000 rotations.
If you add 10 AC generators, one to each mini-pulley,
you would gain a total of 1000 cycles of AC electricity.
These 10 AC generators run torque free, as they only need to generate one spark of DC current,
which is practically zero, and practically zero current, times even massive voltage,
is still equal to practically zero.
You just have to be multiplying AC electricity, when you only input one spark
= small amount of DC electricity that it takes to rotate a motor one single time,
+ get a return of 1000 cycles of AC electricity
These AC generators run free of most all torque, as they only need to generate one spark of DC current, to make this free energy technology self powered, + crank over your DC motor one time
that_prophet
   This GEM free energy technology simply must work, as it only has to generate the slight amount of DC electricity to rotate a DC motor once, with the large 100 cm circumference pulley attached, giving you 100 cm of moving belt. When you run this 100 cm of moving belt past 10 mini-pulleys, you would gain massive amounts of voltage, from these 10 mini-pulleys of 1 cm circumference rotating 100's of tines each, equaling a total of 1000 cycles of AC electricity. That's one small bit of DC current in, that gives you a return of 1000 cycles of AC electricity output. (now try and tell me these 1000 cycles of AC electricity cannot produce on small bit of DC electricity, that you need as input in order to make this a self powering mechanism)
Dog-One
Quote from: that_prophet on April 12, 2017, 01:40:03 PM
I think we tried Joe, to no avail.
By the way, you forgot to post your picture.
that_prophet
+ If you attach a 100 cm circumference pulley to this DC motor it will give you 100 cm of moving belt
If you add 10 free running AC generators, one to each mini-pulley,
= small amount of DC electricity that it takes to rotate a DC motor one single time,
You are looking at the small size of these mini-pulleys + talking about a lot of  torque to rotate them
when they only have free running AC generators attached, which take practically zero torque to rotate
as motors/generators only take torque to turn if they are generating power, which is equal to voltage times current
+ since you only need to generate one spark of current, (the amount to crank over your DC motor one single time)
+ this is to be generated by 1000 rotations from 10 generators, the cost per rotation is practically zero divided by 1000
which is less than practically nothing + I know that I also need 10 full wave bridge rectifiers, to convert your 1000 cycles of AC electricity into your needed 1 spark of DC current
PLEASE EXPLAIN TO ME,,, why is it that you do not believe that these 1000 cycles of AC electricity cannot give you the small amount of DC current that it take to rotate your DC drive motor one single time,,,,,,, (making this unit self powering)
that_prophet
Please, re-post the explanation then, OR try explaining it again
as I just cannot see how these 1000 cycles of AC electricity cannot, (with the assistance of full wave bridge rectifiers)
generate enough DC current to be able to rotate this DC motor only the one time
Quote from: Dog-One on April 12, 2017, 02:05:48 PM
Thanks for posting the pic Dog-One
I think that the pic is needed to better understand how it works
you are using the small amount of electricity to rotate a very large 100 cm circumference pulley
gaining you 100 cm of moving belt, which you run past 10 or more mini-pulleys of 1 cm circumference
if you add 10 free running AC generators, this could multiply your cycles of AC electricity to 1000
+ all for a cost of only turning over your DC motor once
