GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
HIDDEN FREE ENERGY TECHNOLOGY IN BIBLE
GEMs could be used to electrically convert h2o into hydrogen fuel + O2 to have the fire power,
Yet you still have a GEM to convert bad carbon monoxide or dioxide back into O2 + carbon
That way we could have the instant power of the combustion engine,
and still have it in a way that covers up most of its polluting characteristics
This technology is super simple, by just working on the mechanical effects of it not taking 100 times more electricity to rotate a large 100 cm circumference pulley as it does a 1 cm circumference pulley. Yet you can get 100 cm of moving belt off your large pulley, which if you run through one or many 1cm circumference mni-pulleys, thereby multiplying your rotations by 100 times the # of mini-pulleys that you choose to attach. If you simply attach AC generators to these mini-pulleys, you would be multiplying massive amounts of AC electricity.
Every household could have one or many of these GEM power supplies in it.
-   One for every voltage, OR
-   One for every room
As these mechanisms are simple to build
- Not very costly for parts
- - 1 DC drive motor, + at least I AC generator + belt to connect them
- - One full wave bridge rectifier for every AC generator
- - Wire, enough to go from your AC motor(s) to you rectifier(s) + to DC motor
- - - Then you need to connect wire leads from your DC output of your rectifier
- - - - As well as your AC output motors, (just in case you need an AC output)
- - A small amount of Sauder + flux
- - + some metal, wood or plastic, to construct framing for the mechanical parts
- - - of this Miraculous mechanism
We could even put them in our electric cars
- + no more plugging your car in to gain a charge from your house 120V power,
- but we could
- - plug our car's in, to power your house,
- - - with a little voltage conversion
Description of how to build a GEM = Geometrical Electricity Multiplier
. . . . . . . . . . . . . . . . . . . . . <<<free energy machine>>>
--------------------------------(AC motor=AC generator)-------------------------------
You start with a large (100cm circumference) pulley + you attach a DC motor to the center shaft of it
Then you need at least one small (1cm circumference) mini-pulley,
(the more the better) = More generators = higher current capability
<<because more AC generators=higher capability of current flow>>
Then you would need to build a framing system to hold the
-   motor + generators in alignment for the belt to run smoothly
This could be made out of whatever you had in supply,
-   (1)-wood + nails + screws,
-   (2)-metal strapping or lengths of iron rods,
-   (3)-plastic rods + glue
I say that you need a belt, but in reality you could use a strap, elastic, rope or even tied length of string, to connect your large pulley + your mini-pulleys together.
- pretty convenient, for the many Tribulation Saints, who cannot buy anything without the Mark
This technology is simple + easy to manufacture, out of most parts that you could find around any back yard garage. All that's needed is one large wheel with a DC motor on it, and at least one small wheel with an AC generator of the same voltage attached, and a belt or strap or rope to connect them together. Oh yah, you will need at least one full wave bridge rectifier, to convert your AC output back into your DC drive motor.
this way, the Tribulation Saints can have a way of creating free electricity, in order to heat and light their place of living. This would also give them electricity to charge batteries + run radios + other communication devices
http://free-energy.yolasite.com/
Other possible names for the letters of GEM
- God's Energy Mechanism
- Good Electricity Maker
It only takes one spark of DC electricity to rotate a DC motor once. If you attach a 100 cm circumference pulley, this will give you 100 cm of moving belt. If you run this length of belt through 10 mini-pulleys of 1cm circumference, + attach AC generators to them, you would get 1,000 units of AC electricity
THAT'S ONE SPARK OF DC ELECTRICITY IN = 1,000 UNITS AC ELECTRICITY OUT
(please, try to find a way around this AC electricity multiplier)
Torque is not a problem,,, as these generators are only winding up massive voltage,
which is exactly what we need to rotate your drive motor, and practically no current = (only one spark)
This is GOD 's Gift to mankind + as well as the natural world around us
Yet it was + is being hidden by evil spirits
This was Given to us way back in Ezekiel's time, (Ezekiel 1:16)
- yet evil spirits have kept this Gift hidden all these years
- Just look at how ridiculously simple this technology truly is,
- and ask yourself just how gullible we were,
- to not see through the evil spiritual warfare that was hiding it from us.
You can seemingly break the laws of thermodynamics, simply because it does not take 100 times more power to rotate a 100cm circumference pulley than it does to turn a 1cm circumference pulley. They both take the same current = one spark of DC, the larger one only take a slightly greater voltage. You are gaining 100 rotations of an AC generator. These are practically free running, as they are only winding up massive voltage. The physical resistance only happens when you are taking power out of it = voltage times current times duration of time
that_prophet
   My name is Joe, and I now live at a nursing home in Nova Scotia, and if you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking Satan's words for it, when he or the billions of evil spirits throw excuses at you, for why this will never work. My email is one_christian_warrior@yahoo.ca
   This is so super simple, that I be ashamed of being human, and so ridiculously gullible, to believe these ridiculous lies about torque being a problem. These are free running electric motors/generators, and the ease that these can be rotated is going against only the viscosity of the lubricant, or practically zero. Think of it this way, the only resistance from rotation is caused from the power being generated by the motor/generator, which is only one single jolt or spark –(the amount of current that the motor takes to do one single rotation), which is practically zero current, and mostly all voltage, which is the electrical pressure to crank over this large pulley. Especially since we have 1000 rotations to divide it by, so the torque is he minuscule amount that it takes to produce one spark of current, the amount it takes to rotate only the one time, and then divide it by 1000. This is far less than nothing, so these 10 generators should be free running.
that_prophet
This is the biggest deal since the first wheel. You are using simple preschool pulley technology, to not only multiply the # of rotations, but since AC electricity is only made of the rotations of a coil through a magnetic field. It is the next generation wheel, "wheel in the middle of a wheel" –(Ezekiel 1:16). This pulley mechanism is a super simple way of gaining free energy, by only paying for the one rotation of a DC motor with a large 100 cm circumference pulley connected, and getting back 1000 cycle of AC electricity, from 10 attached  pulleys of 1 cm circumference, with AC generators attached, 10X100=1000. I state the Holy Bible quote, as this was the answer that I was given, when I questioned if this really came from the Spirit of God, and not from evil spirits just trying to confuse me. It is in the Bible where Ezekiel is trying to describe what a UFO motor looks like while it was running, with the color of arcing electricity in the motors/generators. So this is not only free energy, by letting electricity generate itself, but a way to travel in the heavens, in what they called "chariot of fire" or "wheels were lifted up". I was thinking that this might have something to do with generating such a massive voltage, that it somehow repels against the voltage of objects.
There is no resistance from the mini-pulleys with AC generators attached. Think about them as free running motors, with nothing attached to them, as there is no resistance to them,,, they are only free running motors, as these 1000 cycles of AC electricity only have to generate one single bit of current, only enough to rotate your DC drive motor one single rotation, (practically nothing)+ torque is only caused when you are generating power, + P=IV or power equals "I"-current multiplied by "V"oltage. So, no matter how much Voltage you are winding up, when you multiply it by practically zero current, it still equals practically zero Power, which takes practically zero torque. Because zero times anything is still zero. All that they are doing is winding up massive voltage, that is used to crank over your DC motor, and because you only have to rotate it one single time, we don't need to create any current,,, only one spark,,, to crank over your DC drive motor once..... no torque is needed.
THIS IS HOW SATAN HIDES THIS SIMPLE TECHNOLOGY
Can I ask you/warn you to be sure and give 10% to the church, (not catholic) as this was a Gift from God, for His Saints,,, Pre-Trib + the Tribulation Saints
PLEASE,,,
Check this out with any Christian friends that you might have, especially mechanical engineers.
Although I tried to give this, (in an earlier version), to 3 churches + one retired Minister so far, with no takers so far. I will send this version to them as well.
I can't understand why no one could see this obviously super simple GEM free energy technology.
Is satan so  powerful, and mankind so unworthy,,,,,,,,,,,,,,,,,,,,,,,,,
Floor
@That_Prophet
Ezekial's wheel in a wheel, must have some significance, other
than that which you have understood it to have.
When one increases the rpm s of the generators (as in your drawings)
by using small pulleys on the generators and a large pulley on the
motor..... one also increases the energy needed to run the motor.
The generators will turn faster, but the motor is also more difficult to turn.
This is Just like on a multi gear bicycle, when one has to push harder
on the pedals when in higher gears.
This may be hard for you to believe but,  that design has been tried many many
times before and does not produce extra energy.
I have had many ideas that did not work out.  Disappointing as this can be,
one must move on / progress if one is to have any chance of finding a free
energy source.
Its not the devel's work, its just the way God and nature designed puleys.
       regards
                   floor
Paul-R
Quote from: Floor on May 25, 2017, 09:19:41 AM
Its not the devil's work, its just the way God and nature designed pulleys.
... and gearboxes.
