GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
Quote from: webby1 on May 26, 2017, 03:56:25 PM
NO!
I am going by my EXPERIENCE.
You ask me to think about it,, why don't you?
Why will you not think abut the counter force, why will you not accept that the gearing that provides the higher RPM also supplies a higher torque back against the prime mover.
what counter force?
these are free running motors/generators
there is no counter force to rotate them
As a side note I noticed that if you get ignored on your thread you post on other threads,, is that the work of a good soul,, or is that evil at work?
yes, I first went on many forums + threads,
trying to get it out to as many as I could, as fast as I could,
this was to give away His GEM gift to as many people as I could
I thought that it was good to give things away.........................
that_prophet
If you can look past the evil whispering in your ear, you can see just how simple this is. Think about how small of amount of electricity that it takes to turn over your drive motor once. It might take plenty of voltage=electrical pressure to crank over this large 100 cm circumference pulley the one single time, but it takes practically zero current, (only one single spark of current). This means that it takes practically zero power to do this, because practically zero current,(1 small bit) multiplied by even massive voltage, still equals practically zero power, which takes practically zero torque.
And then there is your massive output, from your 10 free running AC generators, connected to your mini-pulleys of only 1 cm circumference pulleys. This configuration could produce 10X100=1000 cycles of AC electricity, and all from the one small bit of DC electricity, a mere spark of current. Now do you see why I call this a Geometrical Electricity Multiplier. You are multiplying one small spark of DC electricity into 1000 cycles of AC electricity.
Yes, Joe, everyone reading here and everyone you have presented this idea to all understand perfectly well what you are trying to say. You don't have to keep repeating the same thing over and over, on thread after thread. WE GET IT.
But what YOU don't understand, what you refuse to understand, is that your initial assumptions are FALSE. Hence your scheme will not work. YOU DON'T GET IT.
You are in fact spamming thread after thread, forum after forum, with your FALSE assumptions, which have led you to believe as you do. YOU are the one listening to "demons" !! And you refuse to be helped. There is no hope for you, dear Joe.
You make further claims without support. "Somebody" has told you he has built three of these things that work. But you offer no proof at all of this utterly _revolutionary_ claim. Why don't you ask that "somebody" what he pays for his electricity to run his home, and let us see his last six months worth of electricity bills.
I know why you don't .... and so do you.
Paul-R
Quote from: TinselKoala on May 26, 2017, 07:40:47 PM
He thinks he is pleasing his God who probably got really fed up a long time ago.
that_prophet
The making of GEM free energy technology
You start with one large 100 cm circumference pulley,
+ you attach one DC motor to it, + this is your drive motor,
can be any voltage, as long as the same as your AC generators
Then you get 1-3 mini-pulleys, each of 1 cm circumferences,
+ then you attach 1-3 AC generators to them,
YOU MUST attach all of these pulleys together,
With a belt, strap, elastic, rope or even a piece of tied string,
Now you connect these generators to 1-3 full wave bridge rectifiers,
To convert your AC output back into the DC of your input drive motor,
Then you run wires from the DC output of your full wave bridge rectifiers,
+ run them back into the input leads of your one single DC drive motor,
Now if you only start to rotate your large 100 cm pulley, only a quarter turn,
This will generate enough power to not only start your DC drive motor working,
But it should be able to keep your DC drive motor running perpetually,
It should be able perpetually keep the system running because of pre-school pulley technology,
You see that the 25 cm of belt that you get from only a ΒΌ circumference of large pulley,
Is more than enough belt to give you 25-75 cycles of AC electricity,
By passing this 25 cm of belt by your 1-3 mini-pulleys of only 1 cm circumferences each
So each of these 1-3 mini-pulleys get to rotate 25 times each,
That's 1 to 3 X 25 = 25 to 75 cycles of AC electricity,
Now try and tell me that you cannot get the one spark of DC current,
Out of these 25-75 cycles of AC current
Remember that these 1-3 mini-pulleys are running free of most all torque,
As the only resistance these 1-3 generators have, (other than viscosity of lubricant)
Is the resistance of the power being generated by them,
Which is P=I V, which is "P"ower is equal to "I"-current multiplied by "V"oltage,
+ remember that no matter how high of a "V"oltage that you are winding up,
You do not need very much "I"current, you only need one short bit of current, (practically zero)
+ remember zero times any number is still equal to zero = (law of mathematics)
So,,, even massive "V"oltage times practically zero "I"-current,
Still equals practically zero Power = which take practically zero torque,
= these mini-pulleys are running practically free
Now, please remember, these 1-3 mini-pulleys, with AC generators attached, run practically torque free
because torque comes from generating power, and P=IV, where I is equal to practically zero
(here is a picture that shows basic idea of this GEM tech)
(but the small pulleys should be much smaller + 1-3 not 4)
