GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
webby1
Quote from: webby1 on June 02, 2017, 09:38:01 AM
While the "spark" is happening there is current flow.
While there is current flow there is a counter torque created.
The only current that you need to generate is the "spark"
Only enough current to rotate your motor one single time, (which is practically nothing)
How long does the spark last?
It depends on how fast your DC motor is rotating
At 60 cycles per second, it would 1/60th of a second,
This speed does not matter, because what I was trying to show you,
Was that for every single rotation of your DC motor,
You are, through simple pulley mechanics, getting a return of 100 cycles of AC electricity
So you are multiplying your AC electricity by 100 times, for every mini-pulley that you add to the belt
If your version of "practically zero" is used to equal zero then the time the voltage and current of the spark is happening is zero time,, how much power is there when it lasts for zero time?
The point is, with even one mini-pulley, you are gaining 100 rotations/cycles of AC electricity,
That you can join together, to gain back the small amount of DC current that it takes to rotate once
you are using simple pulley mechanics, to multiply your # of rotations,
which with AC electricity, you are multiplying your AC electricity,
so if you added 10 mini-pulleys + AC generators,
you could get a return of 10X100=1000 cycles of AC electricity,
+ all for only one single "spark" of DC current,
now,,, your input is practically nothing,
only one "spark" of current, (extremely small amount)
+ your output is 1000 cycles of AC electricity
CLEARLY YOU ARE GAINING A MULTIPLE OF THE POWER THAT YOU ARE INPUTTING
(1000 cycles,(duel sparks) of AC electricity, for the single spark of DC electricity)
you are trading one "spark" of DC electricity, (very small amount),
for the 1000 cycles of AC electricity, (a pretty large amount)
YOU ARE USING SIMPLE PULLEY MECHANICS, TO MULTIPLY YOUR AC ELECTRICITY
+ torque is not a problem, as you only need to generate one "spark" of current,
which is practically zero already, but you get to divide this by 1000 cycle of your AC output
sooooo,,,,,,,,, practically zero/1000 which is even less current needed
these AC generators are free running motors/generators
that_prophet
Quote from: webby1 on June 06, 2017, 11:17:16 AM
Do the math,, you have already had how to do that explained to you a few times, with the answers even.
Sorry, but I have nothing sufficiently explained
But I will prove that this works, by other peoples YouTube videos
Why is it that you have not provided a proper mathematical analysis of your idea, why have you not shown a proper mechanical analysis,, why do you choose to use meaningless terms,,
Sorry, but I thought that one rotation of a big pulley,
Giving you a multiple of 100 rotations,
Or in their setup it's only 3-5 times
More importantly, why am I wasting my time with you.
Not sure, maybe a part of you can see past the haze that evil forces are in control of this evil mist,
+ are getting a glimpse of how simple this is,
I can not answer that last one so I will just stop.
This pulley technology works,,,
Here are a couple of ideas that others have,
Knowing or not knowing that it is based on the same GEM technology
Only theirs only has one mini-pulley, + not 3 or 10 like in mine,
+ you can see how these do work
https://www.youtube.com/watch?v=IjN1refTtHg
https://www.youtube.com/watch?v=A1ZGOgcZp_g
https://www.youtube.com/watch?v=RD2GrpBIMXc&t=3s
that_prophet
Guess what,, I do not have to worry about if it works in reality or not,
because others have done it for me,,,, YESSSSSSSSSSSSSSSSSSSSSS
not only have others done this for me, but lots have done it,
+ all with the most positive results. They use the one on one models,
instead of my diagram of 3 to 1, or my theories of 10 to one,
BUT THIS IS PROOF POSITIVE THAT THIS GEM TECHNOLOGY WORKS,,,
Here are a few of ideas that others have,
but just watch + learn THESE DO INDEED WORK
GEM technology is true free energy,
When you use the belt off the circumference of the large 100 cm circumference pulley,
+ run this by 1 to 10 mini-pulleys, off your one centimeter circumference pulley"s"
you are multiplying you # of rotations by 100, times however many min-pulleys that you have
1 rotation of your large 100 cm circumference pulley,
gets turned into 10 X 100 = 1000 cycles of AC electricity
this was free for all to use, in the old first posted gets the patent rights
except for that former President,
That switched the patent law to be more accessible to others
+ In theirs it only has one mini-pulley, + not 3 or 10 like in mine
Quote from: Low-Q on June 02, 2017, 08:23:58 AM
@that_prophet
Build your machine. Theories doesn't make things work, or make sense, untill you have proven that the experiment corresponds to the theory.
If the experimental outcome corresponds to the theory, the theory is correct, but if the theory doesn't correspond to the experimental outcome, you must discard the theory - not the experimental outcome.
Good luck with your build, and please post your experiment here when you're done.
Br. Vidar
that_prophet
+ you can be sure that more people will come out with their own GEM tech
mankind will hopefully move quickly with this new found pulley technology
where in no time, people will be starting up factories to add this free energy tech
to all electronics + electric mechanisms + yes, even automobiles,,,,,,,,,,,,,,,,,,
can you imagine cars that don't cost any fuel to travel, any amount of distance you want
+ think of how the cost of everything will go down, with no fuel costs to transport stuff,,,,,,,,
PLEASE DON'T FORGET, THIS FREE ENERGY MECHANISM WAS FOUND POWERING A UFO
in Ezekiel 1:16, so we need to experiment with this tech, + see how it can be used in levitation
Low-Q
Quote from: that_prophet on June 09, 2017, 09:21:56 PM
The largest motor have a much smaller rotor than original. This will make space for a small battery inside (multiple button cells). The battery is connected to the terminal and the commetators/brushes when the rotor is turned fast enough (Centrifugal switch).
Therefor he measure zero voltage on this motor when it's not running to "convince people this is not a hoax.
There is videos on youtube revealing this trick.
Vidar
