GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
To rotate your DC motor, with a large pulley attached, you need a lot of voltage, + practically zero current, (1 mere spark) only enough current to crank over the DC drive motor one single rotation. With this one rotation of your DC motor, you are also rotating a 100 cm circumference pulley, which gives you 100 cm of moving belt. If you run this 100 cm of moving belt past one free running, one-centimeter circumference pulleys with AC generators attached, you would end up with 100 cycles of AC electricity. Yes, that's only paying for one rotation of a large pulley, using pulley mechanics, giving you a return of 100 rotations of a mini-pulley, +  by adding a free floating AC generator, you are gaining a total of 100 cycles of AC electricity.
These 100 cycles of AC electricity are running free of practically any torque, as they are used to wind up the massive voltage, which is needed to crank over you DC motor only once. (all voltage + practically zero current =(only one spark)). I say spark because it would only take one extremely short burst of current, (just enough to rotate your DC motor one single time)=one small burst of current, if the motor was running at 60 cycles per second=slow, it would only be 1/60th of a second = only one short spark
Torque is only caused when you are generating power, and Power is equal to "I"-current times Voltage, or P=IV. Since practically zero current,(only one spark) times even massive voltage, still equals practically zero power, there is practically zero power + zero torque being created. So, each half of this system is powered by the other half of this system, where the many cycles of the AC generators are just winding up massive voltage, which is needed to crank over your DC motor just one single time.
http://free-energy.yolasite.com/ This is so simple that I want you to be shaking your head, at mankind not seeing the simplicity of this long ago,,, as you are only paying for one single rotation of a large 100 cm circumference pulley, and you are getting in return 100 cycles of one cm circumference pulley, with an AC motor/generator attached.  You are using simple pulley mechanics to trade one rotation for 100 rotations. Yes, the large pulley would take more voltage/pressure to rotate, but guess what your motor/generator on the one centimeter pulley is busy generating,,,,,,,,,,,,,,,,,,, MASSIVE VOLTAGE.
I want you to see how simple this technology is: http://free-energy.yolasite.com/, so that you can see through this spiritual fog that hangs over us, as we come closer + closer to the first Door = 2020,  closing for His Return. http://my2020vision.yolasite.com/. This is a door that we are not only allowed to know, but commanded in Greek "know that it is near, even at the doors" Mat 24:33 http://doorschristmustpassthrough.yolasite.com/, because this free energy is meant for the soon coming Tribulation Saints. I want you to be able to see through this evil darkness that satan =(the god of this world-2 Cor 4:4) has set over our unknowing + unbelieving world.
ONCE YOU SEE THE UTTER SIMPLICITY OF THIS GEM OF A GIFT = FREE ENERGY, I hope that you will start looking at the BIBLE, for the Truth that it is. http://beliefstoliveby.yolasite.com/, and see how the free gift of Christ's Salvation, solves the problem of us humans, being able to live with our Holy Righteous GOD. Who we are made in the Image of = Father/Son/Holy-Spirit = mind/body/soul
that_prophet
How GEM free energy works
This runs on inputting an extremely small amount of power into a DC motor, (1 spark of current)
To drive a large 100 cm circumference pulley one single rotation, giving you 100 cm of moving belt.
+ it drives a 1 cm circumference mini-pulley, for 100 times. + if you add an AC generator to mini-pulley
Giving you an output of 100 cycles of AC electricity, all for one spark of DC electricity input
How can you not gain power, when you are trading one short burst of DC electricity for 100 cycles of AC
Surely you can gain more than one spark of DC current, out of 100 cycles of AC electricity
These mini-pulleys run free, as they are just winding up massive voltage + use practically zero current.
+ Torque only occurs when you are generating power, the more power, the more torque
Power is equal to I-current multiplied Voltage, or P=IV
We are not generating practically any power because no matter how massive the Voltage is
With the I-current being practically zero, this means that the power being generated is practically zero
Meaning that the amount of torque that it takes to rotate these mini-pulleys is equal to zero
You are just using one single rotation of your large 100 cm circumference pulley to give 100 cm of belt,
+ then you run this long 100 cm of belt past one free running mini-pulleys of only 1 cm circumference,
If you attach an AC generator, this will gain you the amazing return of 100 cycles of AC electricity
That's right, you are only inputting the small burst of DC current, that it takes to rotate a DC motor once, which is through the free properties of pulley mechanics, (trading one rotation, for 100 rotations)
+ the one rotation of a 100 cm circumference pulley does not cost 100 times more power to rotate.
yet you are gaining 100 times more AC cycles of electricity.
This is how you are able to use pulley mechanics, to actually multiply AC cycles of electricity
that_prophet
This http://free-energy.yolasite.com/ technology runs on 100 cm circumference pulley one single rotation, giving you 100 cm of moving belt. + it drives inputting an extremely small amount of power into a DC motor, (1 spark of current) to drive a large a 1 cm circumference mini-pulley, for 100 times. + if you add an AC generator to mini-pulley, giving you an output of 100 cycles of AC electricity, all for one spark of DC electricity input. How can you not gain power, when you are trading one short burst of DC current for 100 cycles of AC electricity.  Surely you can gain more than one spark of DC current, out of 100 cycles of AC electricity
These mini-pulleys run free, as they are just winding up massive voltage + use practically zero current. + Torque only occurs when you are generating power, the more power, the more torque. Power is equal to I-current multiplied Voltage, or P=IV. We are not generating practically any power because no matter how massive the Voltage is, with the I-current being practically zero, this means that the power being generated is practically zero. Meaning that the amount of torque that it takes to rotate these mini-pulleys is equal to zero
You are just using one single rotation of your large 100 cm circumference pulley to give 100 cm of belt, + then you run this long 100 cm of moving belt past one free running mini-pulleys of only 1 cm circumference. If you attach an AC generator, this will gain you the amazing return of 100 cycles of AC electricity. That's right, you are only inputting the small burst of DC current, that it takes to rotate a DC motor once, which is through the free properties of pulley mechanics, (trading one rotation, for 100 rotations) + the one rotation of a 100 cm circumference pulley does not cost 100 times more power to rotate. yet you are gaining 100 times more AC cycles of electricity. This is how you are able to use pulley mechanics, to actually defeat the first law of thermodynamics + actually multiply your # of AC cycles of electricity.
This is so super simple, that I hope this wakes you up to the powerful spiritual warfare that is going on all around you, in this godless world. You are only inputting the smallest amount of DC electricity, (massive voltage, but only one short burst of current, and you can get 100's of cycles of AC electricity back in return). Through pulley mechanics you are trading one rotation of a large 100 cm circumference pulley attached to a DC motor, for 100's to 1000's of rotations of a 1 to 10 of the 1 cm circumference pulleys attached to AC generators. These AC generators run with practically no torque, because these 100 to 1000 rotations only have to generate the smallest amount of current, (one spark). They are just winding up massive voltage, and only have to generate one small burst of DC current, just enough to rotate the DC motor one single time. This is now a self generating set of DC + AC motor/generators, allowing you to tap off of them DC + AC electricity.
This is a technology that will be needed by the Tribulation Saints before 2022.49 arrives, (door for Great Tribulation) http://my2020vision.yolasite.com/ when not only the door closes on Christ's first arrival in the clouds,(2019.04), but the door closes for the second half of the infamous 7 year Peace Treaty closes http://doorschristmustpassthrough.yolasite.com/ I can only hope, that you will start looking into the Bible, for ways to survive this coming trial of mankind, http://beliefstoliveby.yolasite.com/ when half the population of this earth will not survive. Or even better, becoming born again, + using the "blessed hope" to be able to go to the Wedding of Christ + escape the coming judgment on mankind.
profitis
"Bs!"
Bcareful.there is ONE part of the bible that stands the
test of time and that is: MARK 3,29
