GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
I happen to be disabled + on disability pension, + I love + spend most days studying His Word,
so I do any errors honestly, but thanks for the warning
sorry that I could no longer edit my last words,,,
so I must rewrite this whole page, to make changes,
Yes, this is the last of the end times,.2020 is when the first door will close.
http://my2020vision.yolasite.com/
This is when we will need free energy
How GEM = free energy device works
This http://free-energy.yolasite.com/ technology runs on a large 100 cm circumference pulley one single rotation, giving you 100 cm of moving belt. + it only takes inputting an extremely small amount of power into a DC motor, (1 spark of current) to drive a large pulley one single time, causing a 1 cm circumference mini-pulley, to rotate 100 times. + if you add an AC generator to the mini-pulley, gives you an output of 100 cycles of AC electricity, all for one spark of DC electricity input. How can you not multiply your power, when you are trading one short burst of DC current for 100 cycles of AC electricity.  Surely you can gain more than one spark of DC current, out of 100 cycles of AC electricity, to make this a self powering device. This pulley technology freely multiplies rotations, and AC electricity is made from rotations, so you are actually multiplying AC electricity.
These mini-pulleys run free, as they are just winding up massive voltage + only need to generate practically zero current. + Torque only occurs when you are generating power, the more power, the more torque. Power is equal to I-current multiplied Voltage, or P=IV. We are not generating practically any power because no matter how massive the Voltage is, with the I-current being practically zero, this means that the power being generated is practically zero. Mean that the amount of torque that it takes to rotate these mini-pulleys is equal to practically zero. Each half of this free energy powering system, generates more than enough of the input power for the other half of this self powering GEM=(Geometrical Electricity Multiplying) mechanism. The massive amount of rotations of the mini-pulleys produces more than the voltage needed to crank over your DC motor once. + The 100 cm of belt off your large pulley, is more than enough to rotate your mini-pulley enough times to gain the one single burst of current, when put it through a full wave bridge rectifier.
You are just using one single rotation of your large 100 cm circumference pulley to give 100 cm of belt, + then you run this long 100 cm of moving belt past one free running mini-pulleys of only 1 cm circumference. If you attach an AC generator, this will gain you the amazing return of 100 cycles of AC electricity. That's right, you are only inputting the small burst of DC current, that it takes to rotate a DC motor once, which is through the free properties of pulley mechanics, (trading one rotation, for 100 rotations) + the one rotation of a 100 cm circumference pulley does not cost 100 times more power to rotate. yet you are gaining 100 times more AC cycles of electricity. This is how you are able to use pulley mechanics, to actually defeat the first law of thermodynamics + actually multiply your # of AC cycles of electricity.
This is so super simple, that I hope this wakes us up to the powerful spiritual warfare that is going on all around you, in this godless world. You are only inputting the smallest amount of DC electricity, (massive voltage, but only one short burst of current, and you can get 100's of cycles of AC electricity back in return). Through pulley mechanics you are trading one rotation of a large 100 cm circumference pulley attached to a DC motor, for 100's to 1000's of rotations of a 1 to 10 of the 1 cm circumference pulleys attached to AC generators. These AC generators run with practically no torque, because these 100 to 1000 rotations only have to generate the smallest amount of current, (one spark). They are just winding up massive voltage, and only have to generate one small burst of DC current, just enough to rotate the DC motor one single time. This is now a self generating set of DC + AC motor/generators, allowing you to tap off of them DC + AC electricity.
This is a technology, that will be needed by the Tribulation Saints before 2022.49 arrives, (door for Great Tribulation) http://my2020vision.yolasite.com/ when not only the door closes on Christ's first arrival in the clouds,(2019.04), but the door closes for the second half of the infamous 7 year Peace Treaty closes http://doorschristmustpassthrough.yolasite.com/ I can only hope, that you will start looking into the Bible, for ways to survive this coming trial of mankind, http://beliefstoliveby.yolasite.com/ when half the population of this earth will not survive. Or even better, becoming born again, + using the "blessed hope" to be able to go to the Wedding of Christ + escape the coming judgment on mankind. This free energy technology can be found in the Bible, where Ezekiel is describing what a UFO motor looks like, while it is running. (Ezek 1:16)
Quote from: profitis on August 04, 2017, 03:08:40 PM
"Bs!"
Bcareful.there is ONE part of the bible that stands the
test of time and that is: MARK 3,29
pulp
profits = that_prophet
Thank you for the bs. again dude.  ;D
that_prophet
Why is it that nobody talks about the soon closing doors, which are deadlines, these are must happen before dates, that we are allowed to know...? (Mat 24:33)
TIME IS SHORT, Yes, this is the very last of the end times, as 2019.04 is when the first door will close.
http://my2020vision.yolasite.com/ These are Doors that we are not only allowed to know, but in the original Greek, it is worded like a command,  (Mat 24:33) "know that it is near, even at the doors" These Doors are deadlines, or must happen before dates. Doors are plural, to represent His both Comings = 1-(Rapture) + 2-(Glorious Appearance)
Time is coming to the point when free energy will be needed most, during the Great Tribulation, when people will be forced to take the mark, to purchase or do most anything. PLEASE, NEVER TAKE THE MARK, AS IT MEANS THAT YOU WILL SPEND ETERNITY IN THE LAKE OF FIRE. (a place worse than hell)
JESUS IS GOD, + HE IS COMING BACK VERY SOON,,,
(before 2019.04) when the 1st door closes, for His Arrival in the clouds, to remove His Bride for the Wedding
THIS IS A GIFT FOR THE TRIBULATION SAINTS.
Are you familiar with the abilities of pulley mechanics? - http://free-energy.yolasite.com/ Especially the way that they can use the length of the belt off one rotation of a large pulley, To freely + dramatically multiply the # of rotations of one or many mini-pulleys. This happens to be a most significant advantageous ability, especially when it comes to the cycles of AC electricity. Where you can actually multiply your supply of AC electricity, by simply adding some mini-pulleys connected to AC generators, where the more rotations that you gain, are equal to a greater supply of AC electricity.
Think about how easy that it would be to rotate a mini-pulley of 1 cm circumference for 10 times, with a free running motor/generator attached to it. This motor/generator would be only building up massive voltage, which is just what you need, to crank over your large pulley one single time. Each half of this mechanism has exactly what the other half needs.
To rotate your DC motor, with a large pulley attached, you need a lot of voltage, + practically zero current, (1 mere spark=short burst of current) only enough current to crank over the DC drive motor one time. With this one rotation of your DC motor, you are also rotating a 100 cm circumference pulley, which gives you 100 cm of moving belt. If you run this 100 cm of moving belt past one free running, one-centimeter circumference pulley, with an AC generator attached, you would end up with 100 cycles of AC electricity. Yes, you are only paying for one rotation of a large pulley, + using pulley mechanics, which is free + easy, giving you a return of 100 rotations of a mini-pulley, +  by adding a free floating AC generator to this mini-pulley, you are gaining a return of 100 cycles of AC electricity.
These 100 cycles of AC electricity are running free of practically any torque, as they are just being used to wind up the massive voltage, which is exactly what is needed to crank over you DC motor one time only. (all voltage + practically zero current =(only one spark)). I say spark because it would only take one extremely short burst of current, (just enough to rotate your DC motor one single time)=one small burst of current, if the motor was running at 60 cycles per second=slow for electric motors, would only be 1/60th of a second = only 1 short spark. With pulley technology you can easily + freely multiply your total # of rotations.
Torque is only caused when you are generating power, and Power is equal to "I"-current times Voltage, or P=IV. Since practically zero current,(only one spark) times even massive voltage, still equals practically zero power, there is practically zero power = zero torque being created. This works by each half of this system, being powered by the other half of this system, where the many cycles of the AC generators are just winding up massive voltage, which is needed to crank over your DC motor just one single time.
http://free-energy.yolasite.com/ This is so simple that I want you to be shaking your head, at mankind not seeing the simplicity of this long ago,,, realizing the awesome power that evil forces hold, to hide this super simple free energy technology from mankind for so long. You are only paying for one single rotation of a large 100 cm circumference pulley, and you are getting in return 100 cycles of a 1 cm circumference pulley, with an AC motor/generator attached.  You are using simple pulley mechanics to trade one rotation for 100 to 1000 rotations =(100 X 1 to 10) mini-pulleys. Yes, the large pulley may take lots of voltage/pressure to rotate, but guess what your generator on the one centimeter pulley is busy generating,,,,,,,,,, MASSIVE VOLTAGE.
I want you to see how super simple this technology is, so that you can see through this spiritual fog that hangs over us, as we come closer + closer to the first Door = 2020,  closing for His First Return, in the clouds. http://my2020vision.yolasite.com/. This is a door that we are not only allowed to know, but we are commanded to know, in the original Greek "know that it is near, even at the doors" (Mathew 24:33) http://doorschristmustpassthrough.yolasite.com/, because this free energy is meant for the soon coming Tribulation Saints. I want you to be able to see through this evil darkness that satan =(the god of this world - 2 Cor 4:4) has set over our unknowing + unbelieving godless world.
ONCE YOU SEE THE UTTER SIMPLICITY OF THIS GEM OF A GIFT = FREE ENERGY, through pulley mechanics, you can freely multiply the # of rotations, and since more rotations of an AC generator means you are multiply your cycles of AC electricity, you are using pulley mechanics to actually multiply your amount of AC electricity. By only paying for the one rotation of a 100 cm circumference pulley, you can multiply your AC cycles by 1000, with 10 mini-pulleys of 1 cm circumference, with AC generators attached. (10X100=1000)
Now let me thoroughly destroy this pathetic myth about torque being a problem. These 10 mini-pulleys with AC generators attached, are all free running, as for all of the 1000 rotations of these AC generators, the only amount of DC current that you need to generate, is one simple little spark, or practically nothing. Because that is all that it takes to drive your 100 cm circumference pulley, that will start this free electricity multiplying mechanism running, as it only takes one spark of DC current. Remember that torque only comes from when you are generating power, and the only power that we are generating is practically zero, which takes practically zero torque,, or free running.
I hope that you will start looking at the BIBLE, for the Truth that it holds. http://beliefstoliveby.yolasite.com/ and see how the free gift of Christ's Salvation, solves the problem of us humans becoming good enough, + being able to live with our Holy, Righteous GOD. We don't have to worry about becoming good enough for God, as Jesus-(God the Son) stepped in and solved the problem for us. He Knew that we could never handle the punishment for the sins that we had committed, so He paid for our sins in our place, and all that we have to do is accept his Gift of Salvation.
We are made in the Image of GOD
Father/Son/Holy-Spirit
= mind/body/soul
Yes, I may have chosen the wrong duration, (51.6) for this end time generation, but using the linage of Jesus, the 14, 14 + 14 generations seemed the most likely to me. Now comes what I think of as His Sign of approval. This same duration of time, 51.6 solar years, was used to accurately predict the date of the rebirth of the nation of Israel. RIGHT DOWN TO THE EXACT DAY EVEN.
Quote from: pulp on August 06, 2017, 04:55:33 AM
NO PROB
that_prophet
If you use a large amount of voltage to gain the electrical pressure to crank over this large 100 cm circumference pulley on a DC motor one single time. It might take massive voltage, but it would only take the smallest spark of current. With our modern day 60 cycles per second AC electricity outlets, that would last 1/60th of a second. (which is only a spark to me) With only this short spark of current, you are not creating practically any power, which means that you are not expending practically any torque either, which is why these 1 cm circumference mini-pulleys are practically free running. By the way, guess what this AC generator is building up when it is rotating many times = massive voltage, (which is just what you need to start rotating a DC motor, with a large 100 cm circumference pulley attached. EACH SIDE OF THIS GEM MECHANISM GIVES YOU EXACTLY WHAT THE OTHER SIDE NEEDS. (so, you have a self powering electricity mechanism giving you both AC+DC electricity that you could tap power off of)
Paul-R
Einstein said that the definition of lunacy is the  repetition of the same thing expecting something different to happen.
This clearly defines you, that_prophet, as a lunatic.
