GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
SkyWatcher123
Hi webby, thanks for response, that might work, i'll have to see what the sprocket looks like from the childs bike wheel.
The sprocket that came with the motor is very small, probably not even enough material to put bolts through to other sprocket, would probably need another piece of metal between the two, though will have to see.
I have a question for that_prophet, when you received the instructions of this technology, did they by chance warn you, that demons might attack those that attempted to build these simple devices.
Just wondering, because unless i'm imagining things, i am being attacked by certain individuals around me, it's very strange.
peace love light
Paul-R
Quote from: SkyWatcher123 on February 03, 2017, 02:05:45 PM
I looked up araldite, it looks like a kind of industrial super glue, would that be strong enough do you think.
Its good enough for combat aircraft and missile launchers.
But, although the bonds of Araldite are greater even than the bonds of marriage, it is ESSENTIAL to clean both jobs chemically - or it is useless. Scrub both parts with hot sudsy water and a nailbrush, then, when dry,  with ethyl alcohol if you have some, or propyl alcohol or industrial spirit. Mix EXACTLY equal amounts from each tube and mix very thoroughly.
(This is a lot of work  to demonstrate to that_prophet that he is talking through his back passage. But his God knows this.
that_prophet
Hello SkyWatcher123,
Sorry guys, for bringing religion into this subject, but I was sharing some of my theology topics, as it is this spiritual warfare that the enemy is using TO HIDE THIS SUPER SIMPLE WAY OF USING PULLEY MECHANICS TO MULTIPLYING AC ELECTRICITY.
(I have some newer + more defining descriptions of GEM -God's Electricity Maker )
Quote from: SkyWatcher123 on January 31, 2017, 02:11:38 PM
Hi that_prophet, thanks for sharing, nothing surprises me much anymore, different body, different earth geography, apparently anything can be changed and seemingly in a blink of the eye.
I comprehend the theory of this device and it makes sense to me.
I just realized i can hook up the drive motor to the rear bicycle wheel sprockets, which should make it easier to implement, as the structure is already there to mount the motor.
So based on your theory, we should be able to power the motor, turning the large wheel, in turn rotating the small pulley attached to the alternator and then take the electrical off the alternator and direct that into the drive motor, giving us a self runner.
Though if we have a large enough excess, then we can instead, take the electrical off the alternator(s) and charge batteries.
While these batteries run the drive motor and we can then take the remaining excess from the batteries, in the hope we never deplete the batteries below what we started with.
I have a 24 volt-200 watt scooter motor, i will start planning and see how that works attached to the the rear wheel chain sprocket.
pomodoro
And when it is shown that the concept doesn't work, the guy who is spending his time and money will be a demon in your eyes.
Get some toy motors, rubber bands and a battery and do the experiment yousef for god's sake. Order the parts online if you can't get out.
Don't put so much of your faith in a book that is the creation of man. Test everything you read before you believe it.
that_prophet
Quote from: pomodoro on February 05, 2017, 06:13:42 PM
please,,, please,,, show me how much of a hold that these evil spirits have on you
I was hoping that I could enrage many deceived people,
...... once they discovered how simple of an idea that these evil spirits were hiding
.  .  .  .  .  . but I have not yet been able to break this solid hold that they have on the masses
1 rotation of a 100 cm circumference pulley will give you 100 rotations for as many of the # of
1 cm circumference pulleys attached + with adding simple generators to these 1 cm mini-pulleys,
you can be multiplying your # of AC cycles/units of electricity
---  All through what seemingly legally breaks the laws of thermodynamics
--- --  by using simple pulley mechanics, that we learn in grade school
YES, through pulley mechanics, you can trade one revolution of a 100 cm circumference pulley,
--- turn into 100 rotations of a 1 cm circumference pulley, (for every 1 cm mini-pulley you add)
--- --- so if added 10 mini-pulleys, you would get a return of 10X100=1000 cycles of AC electricity
This is a way of seemingly legally breaking the laws of thermodynamics
By using simple pulley mechanics to multiply your AC electricity
<<< EVil-sOLUTION >>> (isn't it amazing what is revealed by the il-s of life)
Sorry, but I have fallen on hard times, + find myself back living in a nursing home,
where I cannot even have my own personal nail clippers,
so I cannot build anything inside this cage, where tools are forbidden
................ but there is light around the corner, as others have said that they would take up the task,
remember, I have already had one man build 3 different models,,,
but he is worried about the rumors of people disappearing, I mean those who had working models
the Book that I put all of my faith in is the Word of God
you should read a novel  called "Armageddon" by a Canadian author named Grant Jeffrey
which proved to me that the KJV Holly Bible was truly Written by God
as he systematically went through some Bible Prophecies,
and showed how they were fulfilled, even right down to the exact day
it was one of the rules with God, the one about how He gave a second to Israel
