Magnet force shield
Started by Floor, January 21, 2017, 11:14:49 AM
0 Members and 23 Guests are viewing this topic.
Zephir
Too bad that magnetic lines of force cannot be actually shielded permanently, only guided. Temporarily it's possible to achieve everything, but you must be pretty fast - faster than the speed of EM wave spreading in material given.
dieter
If I were about to measure the forces, I would first build a vertical version, containing a track for the shield magnet, sliding on soap or teflon. So the shield can be dropped in from above. Then the shield could also be suspended on a thread, hanging downd from a balance, containing a counterweight, so the gravitational weight of the shield can be reduced to eg. a few grams. Will it slide trough? How much weight is required. Adjustable track, so the optimal arrangement can be found. The push force of the stacks could be measured over a pulley. How much weight can it lift for the same distance?
Something like that.
Experimenting with a reluctance swith, I have just learned that iron "conducts" magnetism much better than a permanent magnet. You would think a PM in a gap of a core is inxreasing the permeability, but actually the opposite happens, esp. with eg Ferrite PM. Seemingly the can transport only a rather low magnetic strength, maybe limited by their own PM strength, way below saturated iron that easily reaches 2 Tesla.
dieter
Sorry about the typos. I can't edit it.
Floor
Quote from Zephir
"Too bad that magnetic lines of force cannot be actually shielded permanently, only guided. Temporarily it's possible to achieve everything, but you must be pretty fast - faster than the speed of EM wave spreading in material given."
End quote
@ Zepher
I don't understand your statement.
Even a helmet struck with a base ball bat does not actually shield the wearer's head. The force is only guided,
      also  again
What does  faster have to do with this ?
              thanks
                floor
@ Dieter
Quote from Dieter
"If I were about to measure the forces, I would first build a vertical version, containing a track for the shield magnet, sliding on soap or teflon. So the shield can be dropped in from above. Then the shield could also be suspended on a thread, hanging downd from a balance, containing a counterweight, so the gravitational weight of the shield can be reduced to eg. a few grams. Will it slide trough? How much weight is required. Adjustable track, so the optimal arrangement can be found. The push force of the stacks could be measured over a pulley. How much weight can it lift for the same distance?
Something like that."
END QUOTE
   I do it like this @
http://overunity.com/14311/work-from-2-magnets-19-output-2/msg487779/#msg487779
QUOTE FROM Dieter
END QUOTE
I started this topic in 2013 but never got back to it.  I decided to work with the magnets only/
http://overunity.com/13354/perm-magnet-only-core-with-iron-shell-motor-coil/msg354318/#msg354318
Not worried about typos
                    regards
                         floor
dieter
That's some intetesting plans there, reads like a patent.
Of course, your test installation doesn't require my advice. When it comes to testing, I really use what's at hand, like wood, cardboard, glue and of course sticky tape. As long as it does the job.
But I wish I had the time, patience and resources to do that like in your pictures.
