Is anyone seriously interested in Free Energy Physics?
Started by aether22, January 22, 2017, 05:31:43 PM
aether22
Ok, I think I safely get it now.
I guess I could try different numbers of pipes.
I think that the coils are wrong as they need to be creating an attracting field surely, and I showed it in repulsion.
I didn't realize that there was no gap when magnetized.
So I think I can try this!
As the pipes/cylinders have nothing going on (no coils except 2), then I can try different numbers easily.
sm0ky2
Yeah yur good with that last drawing
Except back the coils up a bit like its drawn on the left
and coil them tight when you actually build it.
You want the coils to
face each other North and South.
And tape them on good so the coils don't move
You want the metal to attract
aether22
While I have not yet completed the setup, I have found something interesting.
If you take a cylinder with a split, the energy is more intense as the split narrows, and more intense if aluminium tape is put over the ends and even much of the gap so only a single spot remains, the whole device "breaths" in and or out (not sure if in?) through that uncovered spot, making for a much increased intensity.
I could be wrong, but I suspect the intensity (density) IS important as I suspect that the magic happens in part due to the aetheric energy moving through electric and or magnetic fields and ripping/mixing or "processing" the 2 energies until a hybrid energy is created.
John
aether22
Yesterday I tried to make the "PMH" (Perpetual Motion Holder, actually just a demonstration of Hysteresis in crappy steel) by cutting steel pipe.
Alas my bench vice broke as I tried to squeeze the edges of the gap closer to closed :(
So I went with Plan B and bought 12 Dynabolts, these one had 2 different tubes around the main bolt[/size], one cut in the Dynabolt fashion (shapes cut out, 3 cuts in the bottom portion), and the other one which is is just what I am after, a tube with a gap... if a bit small...
Being lazy, I have not yet bothered to replicate the parts of "Mystery Dave's" experiment that were not needed, so instead of winding 2 coils. I only wound one...
And I happened to have the foreign non-magnetic material (a scratch and lose card McD's gave me) not placed next to the tube with the coil...
And I also made an improvement, I found that the field becomes more rotational and stronger if each tubes gap points to the tube next to it as shown in the photo's attached and if one of the Dynabolts is placed in the center.
If I don't get results I'll add the other coil and place the card between the 2 tubes with coils, I might even point the gap outwards which is what I think Dave did from Smoky2's description, though I'm not sure he specified that, so maybe that was just my assumption?
I'll give the card a day or 2 to magnetize, no idea how long was meant to be needed?
Anyway here are photos of the setup, oh and also a photo of a split tube with Aluminium foil both on the edged of the split to increase the reflection of the ends, and also over the gap and ends to increase the density of energy coming from the remaining gap.
The energy from this gap and large tube can be used to bring another tube up to a high state of oscillation, once a tube sets an aetheric oscillation up it persists for at least a while if not continuously.
aether22
I have found that if you place straight lengths of wire or rod between the gapped tubes the energy increases, I already knew of the effect but I just verified the effect was not limited to the circumstance in which I first found it.
In addition I wound a coil and put it in a tube, and the energy increased a lot again!
Here is one example of straight rods connecting the tubes, in this example I only used 4 which is sub-optimal, but it still works nicely.
I also found that it is best if the white mass filling the pipe (ideally a coil) has a slit it it inline with the gap, likely this helps the energy exit, otherwise it might be that it also vibrates in the same manner.
Finally, putting a coil around it leads to a fast flowing aether stream in the wire.
Again many here could probably build this and feel the results.
