re: energy producing experiments
Started by Delburt Phend, February 04, 2017, 09:31:19 AM
Delburt Phend
Now here is a very good one.
I do not know if he would have announced results that would debunk the accepted theory; but he does go to extremes to get the results he wants. He yanks on the string; faster and faster; until he gets the results he wants. Is it possible that yanking on the string adds linear velocity to the ball?
Indeed; does he not say that the linear velocity doubled. He yanks on the string fast enough to increase the linear velocity (tangent velocity) enough to double the original linear velocity.  Now how do you increase velocity? How do you increase linear velocity except with the application of outside force?  He has added outside force.
He yanks on the string fast enough so that the force in the string is no longer at 90° to the original direction of the motion. It is no longer a balanced force but imbalanced.  Thus: he increases the linear velocity of the ball.
If he were willing to accept the correct answer for the experiment he would have conducted the experiment as gently as possible; to make sure that he was not adding external force.
https://www.youtube.com/watch?v=LBeX74AVFgU
Rather than force the wanted answer: why doesn't he rotate a puck on the end of a string on a frictionless plane? And then interrupt the string with a pin somewhere along its length. The puck would continue with the same tangent velocity but in a smaller circle.
This is an important experiment because it proves that in order to conserve angular momentum you must violate the law of conservation of linear momentum.
Delburt Phend
Also check the kinetic energy increase in this experiment. Does it quadruple? Why is that not a problem?
And then this formula L = mvr is used to predict that the thrown mass; in the Dawn Mission despin event, is moving very slow.
Delburt Phend
Does the linear velocity remain constant in this experiment, by Paul Nord?
I could not find an address: but look under;  circular motion paul nord
It is an unwinding puck on the end of a string.
Delburt Phend
Lets review the other hoax formula; The Conservation of Energy.
In a ballistic pendulum there is a small amount of motion lost to heat, but the loss is so small that the linear momentum conservation formula hardly notices the change. In the very same ballistic pendulum experiment this same loss of heat almost makes the kinetic energy disappear. In truth: this massive amount of heat, to explain the loss of energy, is made up. It is just an excuse to pretend that the Law of Conservation of Energy is true.
If the heat was lost then the motion could not come back; but the double despin experiment shows that the motion does come back.
AWHS davjohn41 ballistic pendulum you tube     This is another experiment with actual data: note 4:10 minutes in. The teacher forgot to tell them the accepted excuse.    Styrofoam is not a heat sink.
Delburt Phend
This is copied from Wikipedia: we are given a set of information and then a false statement. And we are missing one needed piece of information; which is the, rotational mass, diameter of the satellite.
Wiki:  "As an example of yo-yo de-spin, on the Dawn Mission, roughly 3 kg of weights, and 12 meter cables, reduce the initial spin rate of 1420 kg of spacecraft from 36 RPM down to 3 RPM in the other direction[1]. The relatively small weights can have such a large effect since they are far from the axis of the spin, and their effect grows as the square of the length of the cables. "
From the picture; the satellite has some equipment extending to give it the 1.7m diameter, but I think its rotation mass radius is more like .4 meters. The twelve meters of extended cable is also a radius.
This gives you an initial rotational velocity of .4 m * 2 = .8 meter diameter * pi * 36 rpm / 60 sec = 1.50 meters per second.  So the faulty formula gives you:  1420 kg * 1.5 m/sec *.4 m = 852 units of angular momentum; which is all given to 3 kilogram (I think it was actually 2.6 kg).
So according to the faulty angular momentum conservation formula the new velocity for the released masses  is only; 852 = 3kg * V * 12 m =  23.66 m/sec.    54 miles per hour       A catcher's mitt can handle 100 mph
So why not let this 72 units of momentum (3 kg * 24 m/sec) re-wrap around the satellite; ballistic experiments prove that it could only give the satellite a rotational velocity of (72 = about 1420 kg * v) = about .0507  meters per second.
This .0507 m/sec is below the 3 rpm that they did get; and the masses were released.
For linear velocity to be conserved the 3 kilograms would have to be moving around 700 m/sec. This 700 m/sec is dangerous; and that is why they are released.
The double despin experiment proves that the satellite could be returned to the original rate of rotation by the rewinding masses, 24 m/sec won't restore the spin.
Yes I know: I have said this before; but it is worth 7 trillion dollars.
