Thanks to ALL for your help!!
re: energy producing experiments
Started by Delburt Phend, February 04, 2017, 09:31:19 AM
Kator01
Delburth,
great, thank you,really  helped me.
Mike
kampen
POWER PLANT WITHOUT MECHANICAL BEARINGS UCRÓS ELECTRIC CYCLE OF 5 KW
Carlos Ucrós Piedrahita
I am the Innovator of THE NEW WAY TO TRANSFORM ENERGY WITH MY UCTÓS ELECTRIC CYCLE SYSTEM
of the Republic of Colombia South America Carlos Ucrós
WhatsApp +57 3012358709
https://www.youtube.com/watch?v=OUiKMm9IHCE
www.ucrosenergysystem.com
I invented it, I am its innovator, and other models such as the modification of oil rockers, I modify them and extract energy.
The small one that I offer you has these measurements and can be to use inside the home are like this:
Dimension 50 centimeters long by 30 centimeters wide by 35 centimeters in height and 80 kilos in weight, it uses 4 small wheels.
I am selling you an autonomous UCROS electric cycle system of 5 Kw 220/230 VAC 50 Hz
for your home or farm and it supplies you with renewable energy without using the electricity grid.
Delburt Phend
Some data from the pulley.
The gate trip time of a 35 mm Atwood's pulley with 60 g on each side equal to the trip times for 105 mm Atwood's with 20 g on each side; and 20 g on the 105 side and 60 g on 35 mm side?
I placed 80 g (77.366 g) on the left side and 60 g (59.185 g) on the right side at the 35 mm diameter of the 4 radii pulley. The trip time of the photo gate after a quarter rotation were 0571, .0565, .0561 sec.  Average .0566 sec
I placed 20.04 g on the left side at the 35 mm diameter of the 4 radii pulley. And I placed 19.8 g on the left side at the 105 mm diameter and 19.8 g on the right side at the 105 mm diameter of the 4 radii pulley. The trip times of the photo gate after a quarter rotation were .0568, .0560, .0571, .0569, .0564 sec. Average .0566 sec
I placed 78.84 g on the left side at the 35 mm diameter of the 4 radii pulley. And I placed 20.23 g on the right side at the 105 mm diameter of the 4 radii pulley.
The trip times of the photo gate after a quarter rotation were .0568, .0563, .0568 sec. Average .0566 sec
All the 20 g drive masses are at the 35 mm diameter. So the 20g at the 105 mm diameter is equal to the 60 g at the 35 mm diameter.
I took the position of proving that it was (105 mm / 35 mm = 3   3² equal 9)  9 times harder to rotate the balanced masses at the 105 mm diameter. That would mean that  1/9 the mass of 60 g each side at 35; would be equal to 6.66 g each side at 105 mm. So I placed 6.960 grams on the right and 6.960 grams on the left side at the 105 mm diameter. I accelerated this with 20.04 g at the 35 mm diameter.
The same arrangement tripped at .0468, .0468, .0467 sec instead of the .0566 sec for the 60 g on each side at the 35 mm diameter.
So mr is off by a few 10,000th (.0566 to .0566) and mr² is off by 100 / 10,000th (.0468 to .0566).  This means that the likelihood of mr being correct is about 99.9% and the probability of mr² being correct is somewhere around zero.
And this proves that energy is not a conserved quantity.
Kator01
Delburt,
why should mr² be applicable ? There is no rotating mass ( exept the "wheel and axle lrn Fzx"). Except for the wheel all relevant masses you compared  are accellerated in a linear way. The wheel can be exempted as it is the same in both cases
Please pay attention to my pm
Mike
AlienGrey
