Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
Belfior
I just have one primary, so I would not know. Seems to me that if you got 0% offset coilcap is does not matter which way it goes or how to current goes.
Jack said using a coilcap as the primary would be the best option, because then the current propagation in the coil is instant. Now I do not agree with everything Jack says. He says only Coulomb's law applies and induction laws don't. To me it is like saying "you are floating on water, so gravity does not affect you". Any coil experiencing a changing magnetic field get currents inducted to it even if it is an open coil or just a ring.
I think you gotta test this now you got a chance! Does it matter if the 2 part primary is CW + gap + CW or if it is CW + gap + CCW wound
Belfior
Hmm you should have your primary over the coilcap. You are supposed to use induction from the primary and not connect flyback output to the coilcap.
Coilcap then has one wire going to load and one end open. Then the other wire going to load and one end open.
PolaczekCebulaczek
Does anyone successfully replicated this negative inductor  http://freenrg.info/Misc/Genesis/
I tried and it did not work, i think that theory behind it is wrong, there is magnetic field between wires, its tiny but still there, its not canceled out to 0.
AlienGrey
looking at this if you want zero inductance you need to wind it like this see pic
results in zero magnetic field.
Don't get me wrong but but what are all the heat sinks for ? and doesn't the LOPT get really hot in that circuit ?
I mean I don't want to throw a spanner in the works but aren't you supposed to use a ramp
driver so the spark charges up then whack! it arks across causing a disruptive spike ?
Ignore me if you want most do  ;D
Allen
