Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
wistiti
Thank you Jack for your reply!
Im thinking to try your concept for winding a generator... Im thinking to replace all the original winding of a generator by bifilar coil and leave it open end and just connect the output to the other open legs... What you think of it?
sincerly!
dieter
It;s interesting to try all kinds if variations, even if the increasing complexity of interaction becomes unhandy at some point. Personally I would rather try to isolate the anomaly as much as possible in order to understand and ultimatively use it.
First:
Is the energy consumption of the basic model WITHOUT ANY LOAD about the same as in a standard transformer without any load?
Second:
When adding a load, does energy consumption rise, sink or remain the same?
If there is indication that it consumes more than just standart losses without a load, then this is a dead end like angus mcwangus (or however)' PMH bucking coils.
Even tho we do not "transport" any electrons trough this OEPC open ends pickup coil, we still cause a reactive magnetic field (although nonlinearly sweeping) and this field brings the primary in phase, which then consumes energy.
However, I'm just going trough the options. But, as none responded to my previous postings in this thread, I must assume there's no sense in writeing further. This is no touchy bs, it's just pointless to keep on talking to a group that does not react, right?
I thank you Jack for publishing these findings, which I keep on experimenting with, although without blog or so.
kr
wistiti
Hi dieter
are you saying you have test it??
If so why you don't share your results?
Thank's
wistiti
Hi dieter,
Sorry for my dumb question...! :(
I have just give a look back at the tread and see your work... ???
What your conclusion so far with your research on it?
