Leedskalnin's Perpetual Motion Holder in Electic form
Started by sm0ky2, February 24, 2017, 11:16:20 AM
Searcher1o1
Back in the day magnetic amplifiers were used in tv's what you wanna bet the tv that SM talks about used a mag amp, the one that imploded.
The pos feedback causes a coupling with the control circuit.
Its not a limitation it needs to be exploited.
Searcher1o1
QuoteYes there is a genuine gyroscopic effect when the units are on.
Everybody has noticed that when held and in operation, the units have a
definite vibration and have a gyroscopic effect.
They seam to resist being moved through the air.
When placed on a smooth surface it is very pronounced.
Some of you should think about that.
17 Rotation of field. . . How many people think about that.
If you could have a field that you could think of as a big ball.
And you could rotate it in two directions what would the ramifications
be?
Two air cores magnetic field in one ccw magnetic field in the other cw.
The device he showed in the garage vid was different from the original device, using only one core.
Searcher1o1
QuoteThe point I wish to make here is that also along with the 500 volt
DC is, yes, you guessed it, the 5 volts three amp AC current!
They are both completely independent of each other except for
some very interesting things I will mention to you some other
time..
First of all, obviously you can have several different output
components in the power output signal.
You can have DC and AC together without any problem.
Why did that mystery person claim that it was a foolish to say DC output
with a 5k Hz component?
Because he was deliberately trying to mislead anyone who might want to
figure out what I was doing.
Mag amp
Searcher1o1
QuoteHas anyone ever done any research on what happens when we
create a magnetic field and revolve it faster and faster.
What changes and at what speed or frequency of the pulsed field
do things suddenly change?
SM knew more than Jack Durbin gave him credit for.
