Perpetual magnet piston generator, magnet torque amplifier.
Started by synchro1, February 27, 2017, 03:15:59 PM
synchro1
 "Overunity Design" pictured below: 4 self cocking units, triggering each other in succession. Once set in motion, this design would continue to run forever! Plenty of electrical output could be drawn just by building pickup coils around the powerful oscillating piston magents. This generator should deliver 3 times the force it takes to run itself, so it could easily produce kilowatts of power.
We can clearly see the "Trigger Sheer" magnet forcfully resetting itself at 5:11 in Ima MagnetFanatic's video:
https://www.youtube.com/watch?v=hvLjgZWl4s8
This "Self Retraction" event adds a super plus advantage to the generator! "Ima MagnetFanatic" says the magnet tube glue dosen't hold up; A threaded brass rod and four aircraft locking nuts would solve that problem
synchro1
This is a bamboo axle and side struts. I used a cocktail coaster to space the 3/4" neo trigger magnet. It bounced pretty good.
dieter
Intresting. A piston motion may utilize the fact that the lorentz force is in 90 deg. to the approaching magnet, also seen in Art Porters design.
Keep it up.
synchro1
This thread appeared tardily. I'm including an updated design. The piston magnets are concealed under the output coils, inside the reciprocating acrylic piston tubes:
