I have working idea for 6000$ usd
Started by ARMCORTEX, March 06, 2017, 02:17:01 AM
nelsonrochaa
Quote from: ARMCORTEX on March 13, 2017, 04:45:51 PM
Probably I said that, to pay only 200$ for a free energy device sounds like a bargain.
Eventually it would have been copied and your money would dissapear.
Me I would have sent you a clean 5000$ if you gave me the real Mccoy.
Public domain or not, if I had the working circuit.
But...Unfortunately you did not give me my overunity... Nope... I was really dissapointed.
Sorry about my opinion , but maybe is your behavior that are not good, to you forward in your journey of your research but i admit that you have "balls"  to show the way you are in life in relation to that theme.
I could never have that behavior, even if I wanted it, because I believe in other kinds of values in life ,  But everyone has the right to change and you may change your thinking one day, attracting more positive things that will let you in the path off sucess .
Good luck
ARMCORTEX
My favorite weather is a cold, rainy day.
Theres nothing more boring to me than holding hands and butterflies with the rainbow.
This is life my friend, overunity is in the mind of a single man, its one man, and his mind, on a quest for infinite power
There is no use in pretending that people here are my friends, if I insult you, you are not my enemy, if you say nice things to me, you are not my friend.
If I feel some distant character is valuable to me, I will take care of this guy and respect him, he rubs my back, I rub his back.
If you dont rub my back, what have you done for me lately? If you do something for me, now I owe you something, I have integrity.
Otherwise, no time for tentative and silly theorists, I dont wanna be here another decade reading bullshit.
nelsonrochaa
Quote from: ARMCORTEX on March 13, 2017, 05:47:28 PM
Understand your point of view and I respect your way of thinking.
We're just who we want to be.
good luck
sm0ky2
Ok Mr. Lawrence
You definitely have my attention
Twice per rotation, per crank, 100% of the tension force
of the rotating mass is applied parallel to the direction of
the crankshaft. (Milkovic Oscillating Fulcrum?)
Tandem two-stroke engines, using angular momentum instead
of a combustible fuel. Like reversing the gears on a grandfather clock
so two weights lift the 3rd and maintain the pendulum, extending the
runtime ^3rd. But unlike the pendulum, your model utilizes 360-degree
rotation, The force does not undergo Milkovic degradation. Rather, the center
of rotation moves as a whole, presenting no negative torque on the rotating
masses. (Chaos pendulum)
Newton's first and 3rd laws.
The larger the rotating masses, the more drive torque on the larger wheel.
I don't know about "ou" without physically testing this, but it definitely appears
to outperform a conventional worm-gear.
It's kind of like a play on the counterweight mechanism inside an electric drill.
Or an advancement rather
The true test would be done with one wheel.
One pair of rotating-crankers, 90-degrees apart.
and I would improve upon the crankshaft mechanism
giving it a more elliptical path
rather than a circular one.
Even in only two dimensions, this could revolutionize the way we handle
large scale machinery and construction equipment.
Not to mention its' applications in the energy industry or transportation.
Really in the entire manner in which we convert torque into motive force.
And vice versa.
Some degree of input is needed to bring the masses up to speed
and to maintain the rotation, but that is (or can be in the right situations)
irrespective of the torque applied to a secondary wheel or actuator.
Want to test this? Mount an imbalanced motor on a table
And measure the current through the motor both:
While the table is secured motionless
And while the table is bouncing around the workshop.
Now calculate the energy it takes to bounce the weight of the
motor and table around the workshop.
markdansie
Quote from: ARMCORTEX on March 06, 2017, 12:18:50 PM
I prefer to put other people's money where my mouth is, I have calculation overunity and hard design, I need other person's money. 30% is something I am happy with.
I need big money person, who gambles this type of money on a weekly basis.
The reason they are rich they do not gamble. They rather wait for proof of concept. You need something other than calculations to convince them.
Kind Regards
Mark
