Self running magnet piston generator.
Started by synchro1, March 07, 2017, 05:36:04 AM
synchro1
Scaling up by coupling tube magnets end to end, both on the axle and inside the piston tube would double the throw and the magnet strength resulting in twice the output. "Ima Magnetfanatic" chose 7/8" and 3/4" diameter neo tubes, giving the acrylic tube 1/16 of an inch clearance on each side of the axle magnet. I ordered 3/4" neo tubes and 5/8" neo rings from K&J, resulting in the same clearance inside a 3/4" I.D. acrylic tube ; Therefore, the magnet strength and piston output can easily double or triple with end to end coupling, while the acrylic tube diameter and brass axle stay the same.
Output coils would cover both moving piston magnets held in place by a second stationary acrylic tube as pictured below:
sm0ky2
shylo
shylo
It's funny everybody follows the same path.
2 Fields, offset the fields by having 2 poles against one, or vise versa
You can't have them acting beside each other.
90 deg. seems to be about the best, still checking
If it self runs It will not likely power much of a load.
artv
