The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
onepower
Nelson
Thank's for posting your circuit and it is very interesting.  I see you are using the three capacitor series oscillator with an embedded parallel oscillator as in your last circuit. The series bypass has also changed with a similar energy split on the inductive discharge. As if to say if the load wants to inhibit our oscillations then let it and we will simply store part of the energy elsewhere.
Very few people reach the required level of operation to sustain a device using spark gaps. Even less people progress to using discharge tubes such as neon's or threshold detection circuit elements. Almost no one has reduced the required effects to solid state operation so far as I know... well done.
The next level is to remove the switch at which point switching is replaced with field interactions and operations. I suspect it follows the same logic as a logic gate would. If something X happens and something Y happens then Z must happen unless X or Y have changed in some way in which case Z does not happen. In this case, conceptually, many circuit elements or components we are familiar with could take any number of forms so long as conduction occurs and the effects remain. It's kind of mind boggling when we think about it because these effects could appear in organic form or engineered crystalline/substrate structures to some extent on some level that most would never think to question. We have many options and are only limited by our imagination as to how far we could take this.
AlienGrey
onepower realy, when ever i have brought up this subject on the Dally tread I have been slagged of and bad mouthed by those who should have known better but with nelson it's a learning curve.
Nut knowledge in this subject can be dangerous.
onepower
AG
Quoteonepower realy, when ever i have brought up this subject on the Dally tread I have been slagged of and bad mouthed by those who should have known better but with nelson it's a learning curve.
Your post is incoherent gibberish, what subject are you talking about, why were you slagged, why is it a learning curve with Nelson and wtf does "Nut knowledge in this subject can be dangerous" mean? ... are you on drugs?.
AlienGrey
Quote from: onepower on September 13, 2018, 09:25:41 PM
AG
Onepower;  It's the software it changes words it doesn't like. It should read ''Note  knowledge in this subject can be dangerous".
Stanley Myers, Adrian Gustove (not sure on spelling) and many others for there trouble now deceased and no i'm not on drugs
only the shit America puts in our water and food. Why are you ?
I was referring to the gibberish you wrote ie  ;D
Is all Tesla did was to charge a capacitor with energy like a TV saw tooth and dump the energy a spike  into a coil (Tesla coil) producing a huge HF fly back pulse. Not to difficult, yet many on the Dally thread thought it just sucked it out of the air as static.
Perhaps being as you say you know so much about the workings of this phenomena and it's place with in Quantum physics you could explain things like BEMF and how peek return can be achieved ie OU and frequency and materials that could be used and how magnetic Lenz law can be removed and would this produce a radiant circuit we could use to our advantage ?
AG
onepower
AG
QuoteOnepower;  It's the software it changes words it doesn't like. It should read ''Note  knowledge in this subject can be dangerous".
Okay now you starting to make "some sense" and I use this term liberally. I would simply say there are people who go through life scared of things they cannot control and there are people who live there life because we only get one.
