Mervace Working Magnetic motor using induction feedback
Started by Jdo300, November 20, 2006, 01:26:19 AM
allcanadian
If you want to understand OU, you need to understand one thing- Quantum mechanics"
Here is an example- Explain the following to me, no generalizing.
-general relativity
-sonoluminescence
-magnetohydrodynamics
-E=mc(sq)
The fact is 99% of people have no idea, so how the hell would they know what is or is not possible? So they state opinion as fact based on what there Daddy told them, what there teacher told them, outdated textbooks and opinionated media.
I could explain all these 20 years ago, so how would I convince someone having zero knowledge what is or is not possible, you can't.
allcanadian
Sorry for jumping on merv, Im stressed out again,Big time.
As far as his machine goes I have zero interest in building executive toys thank you.
When I see circiuts I gain perspective, like harti's picture, you look at it and say " now why would he do that?" I have seen thousands of circuits everyone uses, most are a joke, everyones pinning caps to common ground, series resistors, voltage regs burning half the power as heat, so when I see something different you learn.
As well you may not have figured this out, but OU isn't all about power generated, it's about efficiency,"what you don't waste". A machine that can run on very little power is very interesting even if it has no value.
Merv
Thanks for your reply Peter.
I?ve just looked at all the posts here. Allcanadian was thinking by  no 96 and was getting hotter by 134  I?m inspired again.   Remember I did two separate things. I build an efficient  movement  then  removed  the battery. I did not consider the solenoid coil  as part of the tuned circuit , Dipole  etc ?.. Just considered it part of the motor  not part of the supply  .. Of course when I had to introduce  large fields to get it to work   that?s when  the bare bones  motor evolved into the device you see now..Then I pursued more normal interests.? So Allcanadian,  your mission today. Should you choose to accept it.  Make the  Adams/Merv   motor and show it all if you wish.  For the less motivated  just   start with  a piece of wire  2 bits of paper and a computer fan just out of view from the camera. I bet someone will do this.  For the rest of you just use a battery   But Allcanadian and Peter. I expect much more from you 2
Why do you not discuss the Finsrud machine. I don?t expect to convince Poor old Omnibus. He has already visited the Guru and became a disciple. I just wonder did he think to take a $2.00  compass with him as he walked round the device and felt a chill in his bones.. Oh yes Finsruds device produces much more than a ball moving in a circle. How much money does it generate? I would like to see the video. I  should  keep quite from now on.  Does anyone have the number of the patient office? I think I seethe men in white coats coming up the drive way
allcanadian
Hello Merv if your machines Rf then you use a tank circuit to recieve, diodes to rectify, cap to store charge, reed switch to break contact on register of magnet, recycle Bemf to small cap , because caps are about voltage- small spike+small cap=large voltage/small spike+large cap=low voltage. Voltage flows from high to low, but a watt of power can be at any voltage.
I would love to build your machine, but unfortunately I have a hot new PM/toroid design Im itching to try. I read my posts here as well, If I wasn't a guy I would say I have PMS.
You will see my new design here soon with data hopefully.
Best regards
Merv
Great Allcan. I cant wait to see your results. Im still thinking about the Finsrud effort
The Finsrud machine.
Well what if it?s a genuine machine. Where is the energy coming from. Consider a free swinging pendulum   sitting at the equator. It sits there and swings. Put it at the north pole and I traces out a circle once every 24 hrs . Put some dominos in its path and you?ve got a clock. But that?s all. No free energy . The earth has moved>    Don?t forget  Finsrud  built his sculpture on a foundation which is spinning round the sun at a million miles an hour. Surley I don?t have to type all this to you. Is there nowhere on the WWW where we can cut and paste this line of thought..??
