Mervace Working Magnetic motor using induction feedback
Started by Jdo300, November 20, 2006, 01:26:19 AM
allcanadian
Hello Harti
When I read Adam's original patent it basically stated that he uses what I call forced resonance, It is resonance but 180 Deg out of phase with the source. This is what I understood from the patent-
A magnet approaches a coil, it is in attraction to the core, a voltage is induced in the coil windings, current flows in a forward direction in the windings.
- if you try to reverse the current flow to repell the magnet as in DC motors, you must first add as much energy to stop forward current as was added by induction, then you must add an amount of energy equal to the attractive power of the magnet to remove it. you pay twice
So adams concluded it's better to take the induced voltage on attraction and send it to charge a cap, but most importantly at register you must stop all forward current or you pay for it, open the circuit stopping all current flow so there can be no backdrag-no extra energy needed to stop the forward current flow. The switch contacts will ionize and arc unless a small high voltage cap is placed in parallel with it. The switch is then closed, all the induced energy on the cap flows back through the coil in a reversed direction repelling the magnet with the same force as was present on attraction- so the attraction/repulsion are a wash/equal. So what do you gain?
Adams called his machine a motor/generator, why not generator, or just motor.
The induced voltage stored on the cap-sent back through the coil in a reversed direction is then sent to a battery, a cap  but not an inductive load which would effect the coil.
allcanadian
Omnibus
@allcanadian,
That sounds pretty interesting. Have you seen Adam's motor working?
allcanadian
No, I built one a year ago- the problem is switching it's not easy, as adams said the time function of the switching element dictates the effect completely. The shorter the switching time the more power saved/gained, you open and close the switch as fast as possible at register without arcing the switch- that's it
allcanadian
What did you think Newman was doing?
Half of the power he generated was wasted by his arcing mechanical switches, but the kicker is solid state switches will fry. With newmans light shows at his switch contacts Im amazed it does anything.
