Witness the Free Energy effect
Started by Theoretical Research, April 16, 2017, 05:16:47 PM
0 Members and 28 Guests are viewing this topic.
Hi,
I've decided to freely help a few people build a simple experiment to witness the free energy effect that I believe is seen in the Steven Marks devices. Sorry but I only have time to help a few people. You should have a good understanding of FFTs, measuring phase angles & resistance at resonance, cores inductance at a given frequency, and preferably a good understanding of classical electrodynamics.
The effect will be obvious. When the core is facing the planet you will see the free energy effect. When the core is rotated parallel to the planet, the voltage is gone. Magnetic fields can also influence space flow. Although I haven't taken such devices to the equator, I suspect there will be a noticeable change in the effect. Once you successfully replicate the effect, you can then begin experimenting with magnets and  eventually replace the gravity effect with a magnet effect.
Here's an outline of the physics behind the electro-gravity-space effect. The theory predicts space is accelerating toward mass. In this case, the planet. That is why light bends toward planets. On the 4th dimension the gravitational space flow appears like a vortex. The equations work beautifully in predicting Einstein's equations. So we have space flowing toward the planet. On earth's surface it's ~ 11,000 m/s. And so if we have stray charge near earth, that charge produces a magnetic field since it's moving at 11 Km/s. If we place that charge inside a magnetic core/toroid, the charge magnetizes the cores in the same way electrical current flowing in a wire through a core would. We can get charge in the core by wrapping copper foil inside the inner core. BTW, you'll need copper foil to do the experiment. In order to get sufficient charge in the core, we need capacitance. To get sufficient capacitance we need to also wrap copper foil on the outer part of the core. If we apply a voltage on this capacitor (inner & outer foil), we get charge, which applies a magnetic field in the core. If we apply AC voltage on this cap, we then get an AC voltage on the core, which we can easily tap into with a core winding. According to the standard model, applying ac voltage to the cap should NOT produce a voltage on the cores winding, but it does exist. Essentially, you're applying drag to the space flow, which will effect the devices weight. You won't notice it with this experiment. It's not until you apply tens of thousands of volts that results in a lot of power that you will notice weight changes in the device along with inertia anomalies. Everyone is advised to copy this text. People say the government doesn't want this level of physics to be released to the public. I completely disagree. This technology is the only thing that will quickly help humanity to populate the galaxy. Having humans stuck on this planet is putting all of our eggs in one basket. A single asteroid could wipe out humanity.
Contact me in private message if you're interested. Sorry if I don't spend much time replying to posts in this thread.
Attached photo shows an example of a magnetic core that has copper foil wrapped inside and outside.
ps I would prefer you have a core found in high voltage tv coils, the rectangle ones that are roughly 3" long be 1.7" wide by 0.64" thick.
Zephir
QuoteIf we apply AC voltage on this cap, we then get an AC voltage on the core, which we can easily tap into with a core winding
Thank You for pointing to potentially important effect, but the simple scheme or diagram of experiment would speed up its understanding.
For example I don't understand, where the capacitor is supposed to be in you photo of core, because the copper foil seems to form short connection all around it - both inside, both outside it.
Hi. The core shown in the photo is an open circuit, not shorted. I would love to spend  time posting here but I can't spend time except on a few people with a lot of experience required for this experiment. That's my quick assessment on the people at overunity.com. No offense to anyone but I know how these type of threads can take off and I don't want to get swept away in them.
If you can take a core and place a few turns and tell me what R is (not X or Z) and L at a given frequency and the core capacitance from the inner & outer copper foil, then that's bare minimum requirement to do this experiment. Honestly that's a simple task for any EE, but I gather most people here are not a EE. The effect is difficult to see unless one knows the exact characteristics of their core and the circuit. It's difficult because the electro-gravity-space effect voltage is extremely small compared to the voltage on the capacitor, which produces significant leakage due to stray capacitance. A self-runner you don't need to measure it over the leakage voltage. You simply apply a high voltage AC signal in tens of thousands of volts produce by a very efficient circuit that charges a batter/cap, which recirculates the energy back to the core cap.
I want to post a self-runner but I need more time to figure out how to design a circuit that's a LOT easier to build and that's self-tuning. This effect varies with location, altitude, outdoors vs indoors. Even if I posted a self-runner with the exact part #'s it would require people with experience to adjust it in order to self-run. Furthermore, I am determined to take a self-runner to Elon Musk at SpaceX / Tesla before releasing it here. If by chance something happens to me, then I'm confident the more advanced researchers here such as TinselKoala will be able to eventually build a self-runner based on my top post in this thread. So there you go. If you copy & save my top post then this technology is safe.
Zephir
QuoteNo offense to anyone but I know how these type of threads can take off and I don't want to get swept away in them
OK, you can create a new thread about it here. This is my new board created just with respect to your/mine negative experience with unmoderated threads at this forum. All posts will be deleted from there on your command without need of further reasoning.  Or at least submit some diagram and I will copy existing info from here into a new thread, which I create myself.
Why do you use pair of cores instead of single one? Should be the coil wound around both cores at once?
QuoteIt's not until you apply tens of thousands of volts that results in a lot of power that you will notice weight changes in the device along with inertia anomalies.
Actually Lauretti, Woodward and S. Sarg already constructed such a drives: high voltage capacitor within magnet or electromagnet.
QuoteThis effect varies with location, altitude, outdoors vs indoors
Well, this is pretty strange by itself - don't you think? According to your theory (as far I understood its principle) it shouldn't vary with exception of altitude. The large ferrite cores can concentrate lotta electromagnetic smog from wide outside - such an effect could be easily confused for electrogravitic anomaly after then. Musk will be sad if your effect would disappear once his rocket would change orientation just a bit..
QuoteIf you can take a core and place a few turns and tell me what R is (not X or Z) and L at a given frequency and the core capacitance from the inner & outer copper foil, then that's bare minimum requirement to do this experiment
OK - let say, I measured R = 9 Ohm, L = 200 mH at 50 Hz and the C = 2.6 pF. What next? It just seems for me, that if the electrogravitic voltage induced on the core winding will be small, then higher number of coil windings would improve the output voltage in the same way, like the usage of higher voltage at the capacitor. The higher frequency can improve the energy if not power density of device too - why not to increase it too?
Bellow is UF86A  MnZn ferrite core I have from ZP40 material (width:85.8mm, height:43mm, round:344mm)
ARMCORTEX
If you want EE help, you are gonna have to pay for his services or do it yourself.
I would not take the theory of a lazy kid seriously until he paid me.
If you could not post a circuit because it would not work for everybody, then I suggest you build it for your own location, if are even able to finalize an actual build with components and an HV source, wires, then press power on and see.
