Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
DrJones
Thank you, Slider!  very exciting - I look forward to your video.
"Well some great news from here - i've got it running ![/size]Set out yesterday to have the connections as per the SFM original, no direct electrical connections to anything.Battery operated signal generator, with signal wire to the magnets on the right side, piece of plastic, the magnets are stuck to the coil.There is no direct connection electrically anywhere. " -- Slider
Slider2732
Video is up  :)
https://www.youtube.com/watch?v=0S0GO3SIGDk
(4min 38sec)
Some notes about the need for a ferrite rod, that isn't in Dr. Stiffler's video's:
It's needed, because the tuning frequency increases with the removal position of the rod. 2MHz equates to the rod mostly in, 9MHz relates to the rod mostly out. Complete removal would therefore result in a higher driving frequency being needed - the 18.753MHz of Dr. Stiffler's being in line with that.
The output from the generator is very low, so the output compared to Dr. Stiffler's videos has to have that factored....plus I don't have the years of experience of tunings that he has !
Lidmotor
Hi.   I have not posted here for a long time.  This Dr. Stiffler project is very interesting and Slider and I are trying our best to understand and replicate what he has done.  It would be great if others here with better equipment would join in.  His 'Stiffler Loop' video is both fascinating and troubling.  It is a 13Mhz sinewave signal sent into the heat sink of an LED board.  There are two slightly mismatched coils and four diodes in the circuit.  That is it --and the LEDs light up.  He explains what is happening but it goes against normal thinking (at least mine).  He states that the current to run the LEDs doesn't come from the signal generator but rather from the loop involving the two coils in resonance.   I'm looking forward to how this project proceeds.  ------Rusty
DrJones
  Good to hear from you, Rusty!  Thanks for your work on this.
This has piqued my interest, also.
Let's note Mark's latest vid on the subject:
https://www.youtube.com/watch?v=0S0GO3SIGDk&feature=push-u-sub&attr_tag=9jhTb1FA_aJONIDz-6
NO direct-electrical connections at all, and a battery-powered signal generator...
Well done, Mark!
--Steve
NickZ
   The way that stray AC can run on the floors, tables,  walls,  etz,  means that the coils and everything else has to be off of any of those surfaces. Like outside, and just using an earth ground. And, also, away from any power lines, cell phone towers, radio stations, etz.  It's also adviceable to turn off the house breakers when conducting these tests, other wise, you may just be fishing for electrosmog.
  Lidmotor, and Slider:  Nice to see you guys posting here.
   Good luck with your tests.
                                                NickZ
