Oscillator Powering 6 Modified Led bulbs
Started by SkyWatcher123, April 28, 2017, 12:06:21 AM
Naija
Quote from: SkyWatcher123 on June 08, 2017, 04:25:16 PM
Hi naija, So if you checked that the led bulb is in proper polarity orientation, connected to the buffer capacitor, meaning flip the led bulb connections around and see if it lights up.
And if it still does not light up, then one or more of the leds on the board are blown, or you did not modify it properly and you have a faulty connection somewhere in the bulb itself.
You have to be careful when connecting the modified led bulbs to the capacitor, if the capacitor has much voltage above the rated led board forward voltage, that capacitor will dump high current and blow the leds very quickly and you will see a small black dot at the center of a blown led.
peace love light
Thank you Skywatcher, I see the red blobs on the center of ALL the leds. Now, how do I solve this problem. Should I use the same capacitor value in the bulb circuitry to avoid destroying another bulb? In this case, 400v 4.7uf?
Should I reduce the number of coils to reduce the 320V across the buffer capacitor?
Naija
Hi Skywatcher, I just measured the voltage drawn by the leds when connected to normal grid electricity and it is 8.5V. The internal circuitry steps down 220V to 8.5V in order to drive the leds. Now, what size of buffer capacitor do you recommend to use in your circuit to operate these 5w bulbs without blowing them up?
SkyWatcher123
Hi naija, a 400 volt, 100uF-150uF capacitor is fine, 4.7uF might be a little too small, not sure.
If that is true, that your led board is rated at 8.5 volts, then 320 volts will surely blow them every time.
So i assume you removed the internal circuitry from the led bulb that is blown, i should have told you to verify the forward voltage of the led board by applying voltage incrementally with straight DC current.
So i am telling you now, any led bulb you modify, check to see the approximate forward voltage.
So the main problem with your led bulb, if you are using 12 volt input to the oscillator, then the modified led bulb will see the full 12 volts, direct from your battery or power supply and instantly fry the leds with all that current.
If you are going to continue to use that model of modified led bulb, you would need to use probably 4 volt input to the oscillator.
This is to prevent direct current flow into the leds and only the flyback spikes can flow into capacitor and/or leds.
I have found, that these radiant spikes like to charge to a higher voltage level, because they are naturally higher voltage and low current.
So the modified led bulbs i use, match this output better.
Can you share some pictures of your setup.
peace love light
casiano
Hi Skywatcher.
I replicated your circuit and it gives interesting results.
First i used 9 led bulbs of 7 watts each at 220v with an              old 5v phone charger and it lights pretty good.Then i         modified all the bulbs and the bulbs are rated at 36v but            the light its far better.
Now i switched the input with 3 1.5v batteries but at output i
conected another 3 1.5 batteries plus 3 leds in paralel.
I used the light for 12 hours and the batteries still has the
same voltage.
SkyWatcher123
Hi casiano, glad to hear you are having good results, do you have any pictures or video to share.
I picked up 4 more of the same model led bulbs today and converted 2 so far, so the setup now has 10 modified led bulbs and will have 12 total, when i modify the other 2.
There is now even more useful light illumination and the wattage reduced to 7.16 watts, from 8.2 watts.
Based on these results so far, i plan to pick up another 4 pack of these led bulbs, so i will then have a total of 16 modified led bulbs.
Actually, it appears to me, that by adding more led bulbs, we can maintain the same practical illumination as the 8 led bulbs, while reducing the input watts.
Because i notice the area where i did not add more led bulbs yet, it is slightly dimmer, but not much at all, though more illumination in the areas where i just added the 2 latest led bulbs.
So, i conclude, that when i add the other 2 led bulbs to the area where it is slightly dimmer now, that will compensate and probably lower the input watts even further.
This seems to be confirming my theory, that we can get more and more practical light output, by using more and more led diode material.
Let me explain this another way.
Say we start with one 8.5 watt modified led bulb, powered to the full 8.5 watts and this bulb outputs around 800 lumens.
The leds from that bulb may be intense, though the practical, full area illuminating capability of just one bulb is weak.
However, if we take 8 of those bulbs, using this oscillator setup and use the same 8.5 watt input, the light intensity may be somewhat lower, though the real world practical illuminating effect is far greater.
And i know some claim this is just because we are spreading around the light, though i say it is because we are using more led diode material, somewhat along the lines of Joseph Newmans teachings.
peace love light
