Split Flux Transformer
Started by SkyWatcher123, May 11, 2017, 01:28:03 PM
ramset
the very quick 5 minute test mentioned here [ link  provided By Seaad today posted again  below RE: Post 646 last year
http://www.energeticforum.com/renewable-energy/10394-bi-toroid-transformer-thane-c-heins-22.html?highlight=toroid+seaad...
COP200 + will  reach MUCH hotter temperature against ambient then equal test with same input power to resistor in control Box... the temperature comparison between the two will tell the story.
curious if you tried this simple test recommended By member Vortex1 here last year ?.if so and your Device ran hotter than control with same input...truly a merry Christmas indeed..
respectfully
Chet K
Thanks Grandma
seaad
@ramset
Thanks for your measuring box suggestion. In this given case with a small input signal to the unit a temperature test will be resultless. Sorry.
I can do the happy dance anyway without using that box if you think the mathematical calculation principle I have given above is correct for this my device.
It acts as a normal transformer seen from the input side.
Regards Arne
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=102004029434&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
       "Normal One" to "Special One"
        normal transformer to wattfree transformer
        2 primaries and 1 secondary
What is the power/Kg density ratio for a well organized " normal transformer" by using these technique https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1#
ramset
Seaad..
members need jepeg Images of test equipment, latest schematic and all test procedures [or photos] from energetic forum for proper analysis Not all members here have accts over there ?... I can mirror everything here if you like ...?
or can you ?
with gratitude and respect..
Chet
Thanks Grandma
seaad
 @ramset
You can mirror anytning you like.
@ lancaIV
Any pic or link to a pic of that 5-legged trafo?
