Split Flux Transformer
Started by SkyWatcher123, May 11, 2017, 01:28:03 PM
seaad
Exellent lancaIV
The five legged transformer is my choice if I want to "trick"  my house power meter and save me energy money.
Much easier to build than mine, I presume.
My type I+II probably have a need for HV input feeding but gives OU!
A kvick comparisment test (6 kc- 15kc) gives: High (φ) about 85- 86 degrees as patent says. A weak output voltage as my trafos but with lower output-impedance than my trafos (depending of this tranformer lower phase angle, than mine)
Perfomance about 92%. (90- 99% span)
OU not to expect!
Regards Arne
I never ex(s)pect OU, but want to get ever an high converter work c.o.p. over 1 !
How to treat and translate/converse electro-magnetism :
a. http://web.archive.org/web/20160316101924/http://peswiki.com/index.php/Article:Joe_Flynn%27s_Parallel_Path_Magnetic_Technology_--_by_Tim_Harwood( beside the flux strength augmentation "Losses in the system",  last paragraph)
b. F=BIL and nihilation/ compensation : the B/2B  field strength Volt and Ampere ratio
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19790215&CC=DE&NR=2733719A1&KC=A1#
seaad
Info:
Just a comparison: I made some tests with the "five legged transformer" suggested above and found that I got much better performance with higher frequencies when I used the (Television) HV-transformers.
@10 kHz (80 degrees)  Efficiency In/out =96%,
@30 kHz (86 degrees) Efficiency In/out =99,7%
With SiFe (normal transformer)  I-laminations clamped together and multi turn coils.
@50 Hz  (78 degrees) Efficiency In/out =39% (with the outmost legs HARD clamped as the rest)
@50 Hz  (70 degrees) Efficiency In/out =70% (with the outmost legs not hard clamped = tiny airgaps)
Regards Arne
Quote from: seaad on January 04, 2019, 11:13:36 AM
Info:
Regards Arne
Congratulations for the technical near-unity stage !Now the input and output variance, also under temperature observationwmbr Ocwl
