A3C & X-MAGNETS AND PMF.
Started by ageofmagnetizm, May 19, 2017, 08:07:51 PM
ageofmagnetizm
Two more reports have been published.
Do not miss the last one where testing of
Permanent Magnets Generator of Megneto Mechanic Electro Induccting Rings
is generating electricity with ZERO losses of energy. Read about testing at:
https://sites.google.com/site/ageofmagnetizm/home/magnetomechanics/mpg-mme
ageofmagnetizm
Also do not miss the video of testing of prototype of RF PMG-MMEIR 4E6M,
https://www.youtube.com/watch?v=YdQ07VbeBVI
where Drive Motor with 16.2 watts Li-Ion battery turns
Generator with four coils connected to multimeters showing 97 ohms resistance and 43 volts AC
such that power output is 19.04 watts or in horse power:
Drive motor approx. 0.021 HP input   ---  Generator approx. 0.025 HP output.
ageofmagnetizm
Read new article about construction and function and testing of
the Axial Flux Permanent Magnets Generator of Magneto Mechanical Electro Inducting Rings.
Generator is made as experimental prototype and during various testing has manifested hyperefficiency
- converting energy so that output of electric energy is more than 1000% of input of mechanical energy.
https://sites.google.com/site/ageofmagnetizm/home/magnetomechanics/hyperefficient-generator
Mechanical 16.2 watts power input is being converted into 47, 89, 119 and finally 163 watts electrical output,
what means that energy conversion rate is approximately 1000%.
Following picture shows generator being assembled with four CCCs surrounding eight-magnets rotor.
truesearch
@ageofmagnetizm
This is interesting to me. I'd like to see more of these experiments and results.
Good luck!
truesearch
gyulasun
Quote from: ageofmagnetizm on April 27, 2018, 08:41:17 AM
Hi ageofmagnetizm
I would like to understand why you write electrical output power of 47, 89, 119 and 163 Watts when you do not have any load across the output coils? You measure unloaded output voltage (your digital voltmeter is not a load of course). From your site:
RPM           ohms      volts      watts
400             448         82          15
1400           448         270        163
IF I understand correctly your output watt numbers seems to be calculated from P=V2/R where V is the output voltage and R is the DC resistance of your coil you measure with the DMM. IF this is what you meant, I strongly disagree with this, you need to use a load across the output coil because your coil is an open circuit and no any load current is taken from it.
To correctly estimate efficiency of your total setup, the input power to your drill is to be measured: what is the actual DC voltage and current it draws from its battery when driving the shaft of your LOADED generator.
And for estimating the output power you need to use a power resistor or a incandescent lamp or a LED lamp across your output coil and also measure output voltage and current at the same time to get actual output power (here I assume that for the load types I listed the AC current flowing through them is in phase with the AC output voltage across them).
Then you can compare the input and output power numbers to get an idea on efficiency.
IT is very probable that a useful load when you connect it across the output coil will impose a drag on your drill, making it draw higher current from its own 10.8V Li-Ion battery hence input power would increase.
Gyula
