A3C & X-MAGNETS AND PMF.
Started by ageofmagnetizm, May 19, 2017, 08:07:51 PM
gyulasun
Ageofmagnetizm,
No offense intended but what do you want say with repeating some technical data on the drill you use?
It is okay that this Bosch drill has sophisticated internal circuitry but the brushless motor principle is not Lenz-less, it also draws more current from the brilliant accu as any other off-the-shelf electric motor when any mechanical load is applied on the motor shaft. More torque exerted on the shaft demands more power taken out from the accu, this motor is no exception in this respect.
Another technical notice: you commented my heat dissipation calculation as:
"That is not 3.5 digits wrong.  ...     It fits in bunch of somehow similare result mailed to me by various
engineers across the industry.    ...
All thouse results fit not far from the center of statistical core and are similar."
And you then, after mentioning some calculation problems to be considered, wrote this:
"Hence if one is interesting in new processes there are many ways to go around with stats,
I dont mean people seaking reason to lauth Such as: aha my calculations shows that it does not 1000% but only 200%, What a fake.  Do not expect to see truth from one testing played on you-tube, there are many testings released with two last reports, and integration of them is sufficent for conclussions."
No offense again but where is your measurement where you found even 200% efficiency?
In your last two load test reports (if you mean that) this does not get proved at all, unfortunately.  On the contrary: it proves low efficiency, less than 100%, unfortunately.
So what you say?  Again avoid answering relevant questions?  That leads to nowhere if you disregard professional comments either from the industry or from here.
Gyula
Belfior
Gyula I would spend my time somewhere else. It would make it wort something.
When somebody is convinced they are right and accept ZERO criticism and actual scientific methodology you are fighting religion not scientific reasoning.
It is the same thing if you want to create a wine drinking incest cult and base it on the bible you can do that just by picking stuff all over the book. Something you measure and something you read from a box label, but you only use he stuff that proves you are correct.
I can also create a youtube channel where I take a shit every morning, stick a resistor in it and measure it with DMM. I would get 2 million subs in a year (japanese people mostly...). Then I could use that as proof that I am correct and you with your 15 subs are wrong!
ageofmagnetizm
Absolutly, Belfior,
Wast no time on saleing transducedrs here, my stats are less than 1000 visitors per month,
post where millions of visitors can read your adds. I do not encouradge "just sayings here".
citfta
Ageofmagnetizm,
Don't you find it strange that not ONE single person on this forum agrees with your conclusions that are based on false and misleading ideas?
Believing the input power is the same as the manufacturers data sheet shows a very clear lack of understanding about how things work in the  REAL  world.  The data sheet only shows what the normal input power would be under normal conditions.  That data means nothing under actual conditions.
As I have already posted, it is time for you to move on to some other forum.  Maybe a forum that is dedicated to accurate measurements of power in and power out.  Then you could learn how to properly calculate the efficiency of your generator.  Of course with your attitude you will probably get banned after your first couple of posts.  But hey, such is life.
As the old say goes "Move along, there is nothing to see here!"  I of course am talking about your generator with it's unproven claims.
ageofmagnetizm
Gyula, I am not mad on you at all, you persistant criticizm only means that you are not ignorant
mugs saleing person but rather made emotional approach, which became coller and constructive.
I rather respect you for your persistance, which is the second thing which is common to both of us.
I simply don want to talk drills because I know them for to long and that 16 watt one I know not just from testing,
if you want not to spend time for obtaining an absolute information on that drive  - simply aplly variants with
small margin of errors and that would not make much influence on larger stats, I would not believe that you believe that
that drive can do 100 watts when it is desighed for light jobs,
also I hope that yo dont believe that coils producing 100 watts of heat because that such transver can burn fine wire instantly.
About ampers. You've got that not far from meassured, only might had soft for standard model generators,
while soft for u- or O-transformers where coils are far from each other will gives you higher amperrage,
stil that soft is not designed for MMER-Generators where magnets induce core slighly better than primary coils of transformers.
Innitialy I was desiging generator for premium minimalization of losses and it just went much further than that.
If you assume just half amper that will be to little but would not make larger stats insignificant.
