Testatika small machine testbed
Started by Steven Dufresne, April 21, 2005, 08:51:24 PM
0 Members and 40 Guests are viewing this topic.
EMdevices
Nice build Motorcoach.
I would like to offer some advice to anybody trying to replicate.
It is obvious the machine as a whole resembles a Whimhurst machine !!   As such, the principles involved should first be understood, before other exotic notions are entertained.
Take a look at this link to see how a wimhurst machine operates.  http://www.coe.ufrj.br/~acmq/whyhow.html
Here's a paragraph from this link that's revealing:
The output current of a Wimshurst machine depends essentially on the area of the ring occupied by the disks and on the rotation speed. See how. The machine acts as a current source for a load connected to its terminals, including losses by internal corona and sparking. Curiously, only one disk contributes to the output current, because if the charge of one sector is removed by a charge collector, the potential at the corresponding sector in the other disk decreases due to the relatively high capacitance between the disks, and the potential difference between this sector and the charge collector becomes too small for a discharge across the air interval separating them. It is possible to collect charge from just one disk instead of from both disks. The obtained current is a good fraction of the regular output due to the same effect. It is even possible to eliminate the neutralizer from the side where current is taken, with the output circuit serving as neutralizer, but in this case the machine is less reliable, requiring a short-circuit at the output for startup.
Note that the machine is a current source.  As we know,  a current source produces the most power when going into a high impedance load.     P = I^2 R,  where "I" is the current, and 'R' the load resistance.   So the higher the impedance of the load the more power is delivered.  Another way to think about this is to realize that with a high impedance we have a huge voltage given the same current, or V = I x R,  so it's good to build up high voltage.
The real inovations of the Testatika, over the well known Wimhurst machine,  seems to be the following:
1)  Improved charge carriers  (plates don't carry as much charge as grills, so grills are better)
2)  Use of the high voltage developed, to drive and turn the machine. Not by electrostatic means, but by electromagnetic means, using magnets and coils and comutators.
3)  Matching of the load impedance to the source impedance of the machine.  This is the most crucial.  One spark and all the built up energy goes wasting as heat.
The most important aspect seems to be #3.  If this can be acomplished then #2 can be acomplished.  #1 is a no brainer.
So the real question is how to effectively use high voltage static electricity?
Inductors come to mind. A quick contact to an inductor would build up magnetic fields and discharge the main capacitors in a controled manner.  This is just a start.   Diodes can be involved of course as we keep hearing about "rocks" from Stefan.
To me, overunity was always associated with the Wimhurst machines.  Studying their balanced design and the ingenous induction principle always conviced me that they were special.
So here is a test:
1)   Ramp up a Wimhurst machine to high voltage and connect across a voltage divider made with resistors.  Choose realy high total resistance like   100 M ohms.
2)  Then measure acurately the speed of the shaft and the torque on the input shaft to get an idea of the Power Input.
3)  Calculate the Power Output from the voltage divider.
This should show if Pout is greater then Pin.  If it is not, increase the resistor value even more.  The voltage will only build up higher and higher up to breakdown.  A good design will have a high breakdown voltage hence a great performance !!
EM
mungibung
Hello all,
I've been looking on the net for quite a while and the best site fort info and pics I have found on the testatika machine is here, this cleared up many of my ????? on the subject. Ihope this helps someone, it did me
                             Michael
http://rimstar.org/sdenergy/testa/
Steven Dufresne
FYI Today, I tested my single disk small machine with vinyl sheets
on the back. The output for the tests were the side antenna keys
w.r.t. ground. There's a big difference in measured voltage when
I let the vinyl sit for a while and let the charge dissipates from
when I rub the vinyl with my hand. See:
http://rimstar.org/sdenergy/testa/smallmach2_test3_vinyl1.htm
This was all as expected based on my older tests with a vinyl
record for the back disk of my two disk machine but I had to
try it. I tend to think that the whole backing plate is vinyl
and that the two plates on the back are metal but what I did
today was a simple test.
-Steve
http://rimstar.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
hartiberlin
Thanks Steve for this report,
but your output is only in the 300 milliVolt range.
How much current could you draw from it ?
Regarding:
http://rimstar.org/sdenergy/testa/testamagseries2.htm
you need to have glimmer or other K40 isotope  (Potassium40) containing material
which is excited from the capacitor plates and the magnetic fields.
The Testika is really a magnetic and electrical field excited radioactive decay accelerated
machine.
This way the accelerated radioactive decay is converted to electricity.
As you see yourself with your experiments, the electrostatic and magnetic effects
alone are just too small to get any usefull power output.
The huge power output can only be explained by exciting the mountain crystals
inside their backside Leyden jar capacitors and between their horseshoe magnets
and releasing Beta radiation= free electrons
which produce the huge power output.
This is also the only logical explanation for the huge power output
and Mr. Bosshard always said: "The secret is in the crystals".
Regards, Stefan.
Steven Dufresne
Hi Stefan,
Quote from: hartiberlin on April 08, 2008, 08:43:39 PM
I didn't measure current and I'm sure it would be very small, probably too small for my meter. But the point was just to show that with the disk as a variable capacitor, using a triboelectrically charged backing gives significantly higher voltage at the antenna keys. It was only to test that one small piece of the puzzle. I didn't think it was the source of the testatika's high power output.
Regarding:
I'm beginning to agree with you, partially. See more below.
machine.
From examining this photo:
http://rimstar.org/sdenergy/testa/misc/test.jpg
I've begun to agree with you, but not for the ultimate high power output. My current working theory is that the high power is produced in 3 stages. The first is the variable capacitor giving alternating voltage. The second is from the three small pots in the front using stimulated radioactivity to boost the charge that is fed into the third stage, the large pots, which tap into ZPE to give their huge output. Since this may not be clear in text, I just put together this webpage with some diagrams:
http://rimstar.org/sdenergy/testa/th3stagepower.htm
The tall capacitors in the back may play a role in pumping up the voltage needed to get he medium voltage AC from the disks as variable capacitors, since the charge on any triboelectric material may decrease over time. The charge from the tall capacitors may also be needed in the rotation circuit.
Since I'm nervous about working with "stimulated" radioactivity, I'm working mostly on stage 3 and feeding it by other means.
By the way, Stefan, on my 3 stage power theory page (the link above), I quote you a bit. Let me know if I got it wrong and I'll fix it.
-Steve
http://rimstar.org
