what happens between a teslacoil the battery the incadescent bulb and the ground
Started by woopy, June 29, 2017, 09:35:22 AM
tinman
For those that want to know how a transmission line works,and how power is delivered to a load via 1 wire.
The second conductor(wire) in the case of experiments carried out here in this thread,and else where,is the ground(ground plane) it self.
https://www.youtube.com/watch?v=ozeYaikI11g
Brad
TeslaScientific
Quote from: tinman on July 06, 2017, 09:17:28 AM
Because if current could be delivered to a load via one single wire,then that current should be able to be delivered to that load,regardless of where that load is placed along that single wire.
But your statement above say's  that one wire cannot light the bulb unless--Quote:When you put a terminating capacitance AFTER the filament, now the energy flows THROUGH the filament, and it lights.
That is correct. There needs to be some form of plate after the bulb in order for it to light--that is the conductor acting as one capacitor plate.
The fact that you need anything after the bulb,in order for the bulb to light,is proof beyond doubt that it is capacitive coupling.
Nature it self shows us this with lightning.
One of the plates is the ground,and the other is the clouds. When the potential is high enough,the discharge arc takes place-over fare greater distances than you can demonstrate with your systems.
So once again,you need some form of plate or antenna !after! the bulb,in order for the bulb to light,and so,the bulb is being lit due to capacitive coupling,and not by current flowing back and forth along a single conductor.
Whether you want to believe it or not,in order for current to flow,there must be a path for it to follow.
Please read,so as you may understand what is happening,and stray from giving wrong information.
I have highlighted the part you are missing.
https://en.wikipedia.org/wiki/Single-wire_transmission_line
At the end of the 19th century, Nikola Tesla demonstrated that by using an electrical network tuned to resonance it was possible to transmit electric power using only a single conductor, with no need for a return wire. This was spoken of as the "transmission of electrical energy through one wire without return".[1][2]
In 1891, 1892, and 1893 demonstration lectures with electrical oscillators before the AIEE at Columbia College, N.Y.C., the IEE, London, the Franklin Institute, Philadelphia, and National Electric Light Association, St. Louis, it was shown that electric motors and single-terminal incandescent lamps can be operated through a single conductor without a return wire. Although apparently lacking a complete circuit, such a topology effectively obtains a return circuit by virtue of the load's self-capacitance and parasitic capacitance
So once again--the bulb lights because of the capacitive coupling.
Brad
Capacitive coupling is the coupling of energy through a capacitance. The bulb is connected by a conductor, not a capacitance.
It makes all the difference where the load is connected along the wire, because you are dealing with high frequencies. You can connect the bulb back to a different point along the same wire in a short circuit and the bulb will still light, because there's a potential difference across the filament, and there isn't a short circuit there at all at those frequencies. That's all it needs. Tesla demonstrated that experiment in public to illustrate the existence of standing waves along the length of a conductor, corresponding to the frequency.
How is one side of a bulb terminal considered a "load"? Why should it light? What is the current supposed to do in this situation? A filament lights because the energy flows through it, so when the filament is made to be a part of the transmission line rather than the end of it, energy flows through it, and it lights. The same energy is flowing, or rather oscillating, along the entire length of the wire, but the wire isn't a bulb filament so you can't see it. Again, put a variable capacitor across the bulb and you will be able to control the brightness through adjusting the capacitance. So again, the energy is not received through capacitive coupling nor does it close any circuit back to the source. The capacitance merely facilitates a sufficient difference in potential across the filament as an isolated part of the system. The bigger the capacitance, the bigger the potential difference, the brighter the bulb. That's all there is to it.
Unfortunately Wikipedia doesn't know any more than the best expert does. And clearly none of the editors have ever bothered to repeat Tesla's experiments because they are quite happy to apply their own explanations which explain nothing. What you say is valid within the bounds of what it's applicable to, but it's most certainly not applicable in this situation. It's a capacitance to SPACE, not back to the power source. Also in the articles the Wikipedia page references, Tesla is speaking of his own design of single terminal bulbs consisting of a single piece of carbon, not a filament which power must flow through.
Quote from: Nikola Tesla
we may consider the inside surface of the bulb as one coating of a condenser, the air and other objects surrounding the bulb forming the other coating.
http://www.tfcbooks.com/tesla/1891-05-20.htm
This is the part that you are missing:
http://www.youtube.com/watch?v=DovunOxlY1k
TeslaScientific
Quote from: tinman on July 06, 2017, 09:50:49 AM
Brad
The "ground plane" is the ONLY conductor. That is the wireless = single wire transmission system. Forget the air.
Also, it's quite easy to measure faster than light propagation, it's all about which path the energy takes. It's right there in Colorado Springs Notes. Take the extra coil conductor length and resonant frequency, and see what you come up with...
Magluvin
Ive always thought of it as electrons being compressed onto one end and depleted at the other end, capacitance in the air or not. Like say if we have a 12v car battery, I would bet that there are an excess of electrons in the outer exposed - lead terminal and a depletion of electrons in the + lead terminal, meaning the lead terminal mass.  If we have a high voltage, high freq nst with an open secondary, I believe that the electrons in the sec are being compressed and decompressed from one end of the winding to the other at the freq of operation. With that, if I connect 1 lead of the sec to ground, and the swing of compression is in the direction of the ground, then those compressed electrons have a place to go and not be only compressed in the end of the winding, whether there be capacitance in the air or not. I will say that the capacitance in the air can help release more from the winding to the ground, but I think that even without or in the absence of the air capacitance that the compression alone in the open circuit could cause currents to flow through the bulb.  In a way, we could look at the earth as a huge reservoir that can accept and give electrons easily as with what we are doing wouldnt put that much of a charge to affect the reservoir charge in any significant way that the exchange would be impeded much. And when we hold the light bulb at the base and 1 wire from the coil on the other bulb terminal, our body acts as a similar reservoir, only not so large, but large enough to take and give electrons, especially at high freq.
The capacitance can help more electron transfer as shown in the vid below, but I do believe that it is not absolutely necessary at high freq hv potential.
Like I keep hearing that the capacitance of a bifi is so insignificant and only parasitic, yet when it comes to these things, the minute capacitance involved seem to be a big part of the explanation for the 1 wire deal.  Capacitance will always be at play. But like I said, I really think there is compression and decompression within the sec of the tc, and even the tiny nst that drives it, of which I use it in the vid to charge the caps via AV plug in the vid.
But, we cant really eliminate the cap effects to really test it all.  But I dont find it hard to believe that if we attach 1 end of the hf hv sec to a chunk of copper that the copper chunk wouldnt give and take electrons being compressed and decompressed on that end of the sec.
And the pics below show the diff between the bulb lighting 1 wire to the bottom and then the top of the sec of the Lil Tc. I am the reservoir.
https://www.youtube.com/watch?v=TR3WmK3qrws
Mags
TeslaScientific
There are a few things that you may or may not know so I'll say them anyway:
It's a natural requirement/condition of 1/4 wave resonance that the current lags the voltage by 90 degrees = 1/4 cycle of the wave = the length of the resonator. Due to the reflections that occur, a standing wave forms, and the current and potential are distributed at opposite ends of the coil. Maximum current is at the ground end, and maximum potential is at the top/free end, 90 degrees or 1/4 wavelength apart, physically, in space. "Free" being the end with the least capacitance.
When one end of the coil is connected to earth or a big capacity, the free end becomes sensitive to parasitic/external capacitance, which throws the coil out of resonance, and if it's too much then it will stop working altogether.
When both ends of a coil are free or have equal capacitance then it will become 1/2 wave resonant. Through increasing the capacity on one end, the coil can effectively be "biased", and the highest potential will be forced to the end with the least capacity, which presents the greatest opportunity to escape from the system. But this will be the end that's most sensitive to external capacitance.
As some of my pictures show, the bulbs are brightest when they are in series with the capacitance terminal on the top end of the coil, because the energy has to flow from the coil to the terminal and back again in order to resonate, and that's where the highest potential is. But I could never hold the bulb in my hand and light it from the top terminal, because the capacitance of my body would throw the coil completely out of resonance, and so in order to do that I would need to retune it to work while my body is connected to it.
On the other hand, when there's a larger capacitance on the ground end of the coil, which includes the primary and its inductance and the capacitance of the circuit etc, the coil is tuned to its natural resonant frequency, and so there's no amount of capacitance that I can add that would affect its resonant frequency, so I can easily hold the bulb to the terminal and light it in my hand without having to retune the coil, because I'm taking the output from the end that ALREADY has the bigger capacity, and the coil is already tuned to output energy. The free end is doing what it's supposed to do - remaining free to resonate with the maximum potential, and the ground end is outputting the energy.
So I would say that for these reasons, your bulb is brighter at one end than the other. If the primary was placed along the centre of the coil, then assuming everything is mirrored, then the bulb should be equally bright (or not) at both ends.
