manhatten project 2
Started by profitis, August 30, 2017, 02:15:41 PM
profitis
"In an interesting paper by Magdi Ragheb, the
author discusses the various mechanisms
whereby deuteron disintegration in condensed
matter through photonuclear and wave
polarization reactions aid in the source of
neutrons leading to the apparent
transmutations being proffered as the source
of anomalous heat in LENR events.
The author relies heavily on the Oppenheimer–
Phillips process or strip reaction which is a type
of deuteron-induced nuclear reaction. In this
process the neutron half of an energetic
deuteron (a stable isotope of hydrogen with
one proton and one neutron) fuses with a
target nucleus, transmuting the target to a
heavier isotope while ejecting a proton."
Some theories may or may not shed light
profitis
profitis
" small explosions
in cold-fusion cells are
not unknown. At the
tops of some cells
palladium-wire
electrodes areexposed
to oxygen and
deuterium (heavy
hydrogen) gases. If the
palladium wires are
not protected by films
of water, the palladium
can catalyze the
explosive combination
of the oxygen and
hydrogen. This
sometimes happens if
a dry spot develops on
a wire. Such
detonations, though,
cause little damage.
The SRI explosion was
much more powerful.
The detonating cell
(only 2 inches in
diameter and 8 inches
long), not only killed
Riley but peppered
three other
researchers in the lab
with debris.
(Charles, Dan; "Fatal
Explosion Closes Cold
Fusion Laboratory,"
Chemical or nuke?
profitis
profitis
"Californium-251 has a very small calculated critical
mass of about 5 kg (11 lb). The low critical mass of californium led
to some exaggerated claims about possible uses for
the element."
Some elements are highly unstable.can we flash-produce a small quantity of an supercritical powerhouse and simultaneously crush it? we just don't know yet
