Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
.i will have to tilt the counterweight only 91 degree from rest position then there will be no need as due to heavy weight of counterweight the device will get back it's initial position without any external influence.
If the device tilt 91 degree then take 40 cm.
Now use mgh
0.5*10*0.4=2 Joule
Impact is 8 Joule
Now tell me where I am wrong.
vikram_gupta11
See the sketches carefully and work of latch pin.the latch pin will work to hold the ball and prevent it from reverse falling down.
The latch pin will be  spring based designed
sm0ky2
Latch the ball inside the cup when you drop it in,
then the rotation will be less.
The ball falls out, therefore you are not lifting it back up.
The ball doesn't have to just reach the 12 o'clock position of the arm,
but has to go all the way back up to where you dropped it from.
vikram_gupta11
I have tested it .the ball is getting more height than  from where I dropped it.
sm0ky2
Your next test should be to place the arm on
an axle, so you don't hold it
then you can build your latch mechanisms
