Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
Free Energy,Dear Sir,
This time you will not disappoint as you will take very much interest in it.
My main problem is lack of resources to build it completely.
But whatever I made is clearly showing Overunity in this mechanism.
This time problem is going to be solved.
vikram_gupta11
Hello Respected Members,
I did this simple work to prove that output is greater than input.
At first sketch details. There is a two tube mounted on a arm .each tube has ball of 1 kg. So total tube sidemass is 2 kg.i have not included tube weight. The counterweight is 1 kg. There is a latch mechanism in both tubes which will allow to fall the both balls verticallly after the arm get 180 degree. The device will oscillate clockwise and anticlockwise from 180 to 180 degree. A brake or lock system will work to prevent the device from further movement and only counterweight will hit this brake. Now as per video. If I drop the both balls from a certain height then the device move and trying to get 180 degree due to impact energy of falling ball s. And yes it will get it but there are some reasons due to the arm is not getting initial position of 180 degree. 1) the device is not using impact energy of the mass of lower tube. 2) the axle is wobbling 3)the dropping mass is dragging down it as there is no latch mechanism to hold the ball or mass. ...But ok. If the each ball mass is 1 kg.and each ball is falling down from 0.5 meter then the kinetic energy will be Using mgh formula Mgh= 1*9.8*0.5=4.9 joule Mgh= 1*9.8*0.5=4.9 joule Total energy will be 9.8 joule.
https://youtu.be/zHggwGWcK3w
But in the video there is need of only 5 cm. to get the initial position then if I use two piston generator and if each generator works with 40 % efficiency then I have 4 joule in my hand as I will use the impact energy of both falling balls. But if I lift up the device only 5 cm then the device will get back it's initial position so there will be need of only 0.5 Joule energy as I will have to lift up only 1 kg. The out put energy is 4 joule and input is only 0.5 joule. Why this is happening? The interesting point is that there will be need of only 5 cm more to lift up the device to reset it on initial position as mass is not an issue in it. Please tell me.
vikram_gupta11
See these two videos.the handheld weight is not  falling down reversely and arm is rotating at 180 to 180 degree.
just want to know can I use the impact energy of falling weights if yes then why it shouldn't work?
..and if no,then why????
In the video one stroke will generate 4 times energy as the handheld weight has been increased.
In second video I have hold the device to avoid wobbling but remember I am using impact energy of only one weight .if both weight fall down at same time then?
https://youtu.be/eqqOPZT9m2M
https://youtu.be/eJYi3uSOQyw
vikram_gupta11
I have increased the handheld weight.
Suppose the handheld weight is 1.5 kg
So the energy generate is 7.5 joule as it is falling down from 50 cm.height
The energy generate by lower tube weight 1 kg
Is 5 joule as it is also falling down from 50 cm.height.
Total energy from initial stroke is 12.5 joule.
Now the device is getting back its initial position of 180 degree so if the first stroke energy is being consumed then I can use second stroke energy,the same 12.5 joule .
So why it shouldn't work as there is clear cut gain in it.??????
vikram_gupta11
  interestingly when I increased the weight of upper tube then the arm is rotating more than 180 degree without releasing the weight but releasing the brakes but not getting back 180 degree.
When I release the weight then the arm is rotating more than releasing the brakes and device is getting back more than 180 degree.
So it is clearly showing Overunity in this mechanism.
I did it just now
