Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
Dear Sir,
I did an experiment with a ball and a spring.when I released the ball from some height then the tube moved down side and spr8 get compressed.it is clearly showing that the ball will work to press the piston as well as lift up counterweight.
The lever analysis even proving overunity in it .
The initial position as per sketch ( left side) has solved all problems in it.
vikram_gupta11
In a clock system if we connect a load then it will stopped immediately but in this mechanism load is not a problem.as ball is free to generate energy + providing momentum.
So it is not a pendulum based clock.
vikram_gupta11
Dear Sir,
If a 10 kg ball is falling down from 2 meter height and again getting it's initial height using 3.6 Joule energy and again Falling down and getting back its initial height then why there is no overunity.
The whole game is depend on lock system and latch pin in this mechanism.
My earnest request to you that you please reconsider it.
I shall be very grateful to you.
sm0ky2
The mechanism is in an unusual format
But the more I analyze different test models
I see it similar to this system
https://youtu.be/hesfXBcgV0s
the small difference in the arc path vs straight drop
should result in roughly the same velocity with similar
masses.
The energy analysis should also be similar.
vikram_gupta11
Dear Sir,
You are correct.but in this mechanism the impact energy or velocity of ball is important not the velocity of whole device as ball is working to create energy.
We will have to ignore the energy at the time of construction as the input is almost 0 as per Left side sketch as the device is already in this position that even we can drop the ball with our breath.
Once we ignore the energy at the time of construction the energy analysis will also support overunity in this mechanism as this device will oscillate forever.
You please ignore the input energy.
