I think someone discovered the true mechanism of electromagnetism
Started by isawit, September 27, 2017, 10:42:19 PM
profitis
"in reality, hardly any virgins."
what u mean.plenty on ground few ontop.just ride
your way up
isawit
Quote from: isawit on September 27, 2017, 10:42:19 PM
MAGNETISM
2 parallel wires at r distance, the free electrons in the 2 wires repel each other with force f=Ke x q1q2/rr, that force is the carrier of energy/moving electric force. if electrons accelerate in wire 1 at 3 volts, electrons in wire 2 will instantly have 3vq1 emf. the true mechanism of electromagnetic induction. same as momentum conservation.
every magnetic atom/magton contains 2 atoms. 2 atoms of a ferrimagnetic matter before magnetize, we put it as 00. if 1 electron moved from 1 atom to the other atom and stays there as 01, the 2 atoms become a magton, it carries a special property now, we call it magnetic force.
01, 02, 03...0n are all magton, but carry different magnetic force strength.
2 magtons attract each other in the direction 01+01, and repel each other in the direction 01-10 or 10-01.
use copper wire winding around an iron core, put a current, the electrons in the wire move in circles around the core, make atoms in the core arrange into 0101 directions all the way. on the pole plane area, magtons are arranged as clockwise concentric circles of 0101 directions, north pole.
reverse the current direction, the pole plane area magtons are arranged as counterclockwise concentric circles of 0101 directions, south pole.
so, a magnet north pole stored clockwise electric force, south pole stored the counterclockwise electric force. the same poles always repel, different poles always attract.
the earth magnetic field is a mistake. there is no field but the force in the universe. sunlight moves electrons moving westward causing earth magnetic force interact with compasses.
there is only 1 force exists, coulomb force f=Ke x q1q2/rr. gravity and magnetic force are both different configurations of electric force.
from http://fuckedscience.blogspot.nl/2017/
Is the theory correct? Please share your thoughts.
I search for the answer/mechanism of magnetism all my life, this the closest answer I get.
isawit
ou is impossible if energy and momentum conservation are universal.
all things have a precise mechanism. science cannot explain the mechanism of magnetic force yet. why is moving current producing circling magnetic field? why is moving magnet producing a circling current? what exactly is a magnetic field? how it interacts with matter and charges?
about faradays paradox, spin magnet no radius direction current (any circling current on the disk? i find no videos yet, don't have the tools to test it), but if you move the magnet up and down, changing the distance to the copper disk, you should find clockwise and counterclockwise ac current on the disk, not radius direction current. you can measure a voltage between any two points on the outer ring of the disk. my prediction anyways. based on my belief of magnet carries circling electric force produced by atoms arranged into positive next to negative patterns. normal matters are formed by neutral atoms next to neutral atoms.
force is invisible, but we can feel/measure it. forces are always there as long as matters/charges exist.
look the universe from an atom. electrons are float on the surface of atom ball.
image positive charge is a ball shape single north pole, negative charge is a ball shape single south pole.
a big/strong north pole will be surrounded by many tiny neodymium south poles, form an atom ball, iron south poles float on that atom ball as electrons.
maybe that's the true structure of matter. assume that is true, follow the f=Ke x q1q2/rr fact, too see the world and everything.
put a strong magnet in each hand, the same pole faces each other, feel the tension? Now wave 1 hand at 90 degrees to the tension, what do you feel the other hand? I feel an opposite vibration force.
if you move 1 hand in a clockwise circle, the other hand will move in a counterclockwise circle.
replace the magnet with the electron, see the mechanism of em phenomenon, such as induction, light, energy.
electrons can only vibrate on the plane parallel to atom ball surface, the changing electrical force transfer to other lines of sight electrons instantly through the force lines of f=Ke x e1e2/rr.
get two magnets, try to feel the repulsion force, action and reaction of both hands. hope you will understand the mechanism of radiation, heat transfer, light, em waves, energy and quanta.
hope einstein has internet.
isawit
between 2 electrons at distance r, there exist a repulsion force f=Ke x ee/rr. that force is act as a lever with the pivot at the center, the mechanical advantage is equal to 1.
if 1 electron is moving at 90 degrees to the force line, the other electron will instantly receive an opposite direction emf. this is the mechanism of electromagnetic radiation, light, em waves, how energy transfer through space.
isawit
em radiation, light, energy all exist within matters. empty space has no matter, no energy, no force, no wave, no photon, no virtual particle no field, no quantum, no bs and colorful holes.
why our science lied so much?
