Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
Quote from: antigrav89 on October 23, 2017, 07:31:46 AM
IMO, the ambiguity about overunity comes from the way energy efficiency ratio is defined.
In the case of electric circuits, we usually define it as the ratio of the output power to the input power, measured in the electric circuit.
But we should rather define it as the ratio of the useful output electric power to the absorbed power, the absorbed power having two origins: the input electrical power and the energy transfered from the active vacuum medium to the system (considered as a open system from the thermodynamic point of view i.e. able to exchange matter and energy with the outside environment).
To achieve energy conversions between the vacuum and the system, the vacuum must be described as a dynamical system possibly modeled as an infinite fluid. This fluid has to be compressible to allow waves to propagate with finite speed (as sound in air) and inviscid (non viscous) for not dissipating thermal energy. In this scheme, particles of matter have finite sizes and appear as stationary vortices. In the normal conditions, vacuum energy is uniformly distributed and matter continuously receives energy from the vacuum and radiates the same quantity of energy (so the mean energy balance is null). So, if this equilibrium is broken, energy has to flow to restore equilibrium. If this non-equilibrium state is maintained, a stationary current can be established.  If we consider the vacuum as a compressible fluid, its density can vary. So, if we are able to create a stationary vacuum energy density gradient, a energy current can be created between the system and the vacuum. Scalar wave solution of Maxwell equations allows non electromagnetic energy to propagate.
The main problem to solve is how to convert this energy into a coherent electromagnetic energy to create an electric current.
This involves that vacuum fluctuations (considered as electron-positron virtual pairs) must be stabilized to allow either the separation between electron and positron charges or the creation of superconducting pairs. The Big Bang theory tells us that such a charge separation is possible, because, assuming that matter emerged from vacuum energy fluctuations consisting of matter-antimatter pairs, matter and antimatter should be present in equal quantities and we should not exist. Several hypotheses might explain this unbalance state:  matter and anti-matter were (very) swiftly separated before mutually annihilating (but where is the anti-matter now?) or a part of anti-matter was converted into matter. Electric circuits where free energy is observed are generally composed of coils, capacitors and magnets (permanent or electromagnets) and the source of energy excess is often attributed to the magnets. Recent studies of magnetic materials that showed there exist numerous interesting interactions between electric current, spin current and the crystal lattice magnetic spins to create magnetic structures such as skyrmions might provide a further insight into ways of understanding how matter and energy interact in magnets.
Thanks for that makes sense to me.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
The person who came up with spitting the atom knew full well creation can in actual fact create or destroy but create and destroy are both incompatible to each other or not varying on how it is perceived which of course defy's cannot create or destroy.
So thanks to the guy who came up with splitting the atom i have now succeeded in accomplishing my idea.
So instead of being slapped with conversion law and being cut off that was my last hope and hooray it breaks all the laws of physics and bypasses the heart of conversion law.
The bit where zpe wakes up to smell the coffee (zpes/vaccum own perpetual process) in conjuction with the power to destory which is what zpe is i have now succeeded in getting zpe to perpetuate.
lltfdaniel1
So yea just to recap.
If you cannot create nor destory then we shouldn't exist simply put if you find the thing responsible for creating us to exist you will have cracked it on the head - i mean it is the holy grail of free energy it has power to create.
If you cannot go faster than the speed of light, what speed is infinity again am correct in saying it is instantaneous in speed no matter the distance.
Anyways happy new year all!
sm0ky2
I believe it was the same guy who figured out about atomic energy
That stated energy could not be created nor destroyed.
He also gave us the equation that relates energy to mass.
E=mc^2
Atoms are not destroyed in fissality, but rather converted to other forms of energy.
The energy output of this is the same energy that went into the fusion of its creation.
sm0ky2
The Law of Conversion is the fundamental principle of Thermodynamic Theory.
It sets the stage for the theoretical "closed system" (which itself is impossible)
The heat-pump, by definition, is not a closed system. But rather designed to
transfer thermal energy between two systems.
Both of which are also Not closed systems.
If it were possible to enclose all 3 of the systems in the heat-pump,
the theory states that they would reach thermodynamic equalibrium.
And once in this state, no heat would be further transferred.
This cannot be verified, due to the impossibility of closing the systems.
