Thanks to ALL for your help!!
Maxim Aliyev replication
Started by justawatt, October 13, 2017, 12:48:40 PM
justawatt
A youtube user made a replication ,His quote
" I sent Maxim $5000. He sent me the coils, diodes, caps, resisters, and a mosfet.   I spent a lot time building the unit. The unit did't work! He said it was a problem with the coils and would send me new ones but never did.  If anyone else purchased this and got it working please let me know!  Maxim no longer responds to my emails. When something is to good to be true it normally is!  I was scammed!  I hope this stops you from sending money to this guy. This is his partners name I sent the money too- Khomenko Mykola Leonidovych.  In Ukraine. "
https://www.youtube.com/watch?v=lxLloV5imr4
gotoluc
Sorry to see you got scammed out of $5k justawatt
I'm very thankful you're taking the time to post your results and unfortunate experience to help others understand that most of OU claims are scams or incorrect power measurement.
I've been researching and experimenting for the past 10 years and never found anything more then 98% efficiency.
It doesn't mean I'll give up just because the possibility of OU is 99.9% impossible.
But one has to think that if the odds of achieving OU are so bad then you should never look elsewhere and pay someone to do what you can't achieve on your own.
You would just asking for problems then.
Thanks for being brave in sharing your unfortunate experience to help others.
Luc
forest
You cannot do this ! Overunity is not about the special coils or frequency or Russian parts or rare electronics ! It is a METHOD you must LEARN and a source you must understand. KNOW-HOW is the only way to build it. A mere wire connection or the wire length may be the reason it won't work.
If you read Tesla patents he explain it between the lines.All must fit together or nothing more then 100% will happen.Sometimes somebody find it by accident, like me in 2005 but many just dismantled the original setup to find out it won't work anymore :( like me.
But it will be soon you will find OU device in your home for cheap producing heat or for any other electric work done... because nobody could hide the TRUTH if public pressure is rising due to climate change. WE HAVE OU EVERYDAY , BECAUSE MAGNETIC FIELD IS THE SOURCE OF ENERGY IN EVERY GENERATOR - we just need to break the implemented feedback loop requiring to burn fuel to spin generator shaft , that's all. Or to construct device with the MAGNETIC FIELD INTENSITY being larger without consuming larger power input. Tesla did that with his capacitor discharge,others did by resonance or by implementing feedback loop diametrically opposite to the one used in generators.
justawatt
previously sold circuit by him to another person 2500$
GeoFusion
Quote from: justawatt on October 13, 2017, 12:48:40 PM
Hi justawatt,
What I can say is, the circuit diagram is missing components. ;) this is serious.
The real secret behind this device is something that VASMUS had shown some time ago and is easy to spot it if you know where to look at.
His coils and operation are same for this one, Maxim just added up more coils to step up the output.
You will need a " modulating " circuit after the harvesting coils direct connected to # 5-6 and #7-8 coils on your diagram.
it will pulse the energy after receiving recified from of energy from the diodes and charging the caps and so on. ;)
remember you want this energy to charge the caps fast since it's HV, making it DC pulsed to the caps will make good amps..
I might someday... try out Vasmus device, but currently on Akula device.
cheerz ~
Visit VASMUS videos, it might give you the hint ;)
