Building The Clem Engine Series
Started by TommeyLReed, November 01, 2017, 09:54:17 AM
TommeyLReed
Hi All,
I just finished this experimental pump just to verify if a internal centrifugal pump can  or can not produce enough rim jet thrust to keep it running.
Tom
TommeyLReed
Hi All,
Part 2 of building the Clem engine and some math to explain my theories.
https://www.youtube.com/watch?v=Y6cU3aHO9eo
Tom
TommeyLReed
TommeyLReed
Hi All,
Been really busy and happy new year to all.
This is the  first stage implosion motor completed.
I will be working on the second stage next.
Tom.
Ron Hammar
Hi Tommey,
You may have thought of this but if not I would like to share this with you.
I have been fallowing you with the Clem motor and I have a suggestion for you to think about. You say it is a water spout effect but I see in that what you are doing is in a way like a spout (for it sucks the water up)but it is not in the same dynamics of a water spout. Richard used a cone shaped drive to move the oil in. Just like the oil pump that would run a long time when shut off that gave him the Idea of his motor.  Water needs to flow faster in the river when it narrows down and some times the water will rise in height to get out or go by the passageway.  I think on the cone rotor you need to have the water moving the same rate and that is shown by having a channel cut into the cone that as it gets to the outer edge it becomes a lesser depth. In the center you have like lets say the cone moves 10 degrees and draws 1 cubic inch of water volume. In that 10 degrees of movement it only travels 1/2 inch. But on the out side rim of the discharge of the cone the 10 degrees is 5 inches of movement and there fore it would send out a smaller stream of water that would = the same volume (1 cubic inch) that is coming into the cone.  This would set up the energy of a water spout that has been discovered to create a dimensional shift in nature.  The tornado  is the same thing and it has been discovered that is how straw has been passed though a pole. It is not by the force of the wind but that the pole shifted and came back into this dimension at the same time that the straw was in the same space. This was discovered in the 90s. I hope you understand what I am trying to say about the cone. Take care Ron at RLhammar@gmail.com
